How can I do this ?
Vernmotor
Mt.vernon oh
I want to put these alum-plates 0.50 thick on my roll bar to hep keeping it from geting scratch up. So I need to bend them to fit..any ideas on how ?
Red Green
South Central Michigan
Set the plate on another tube and use a several hose clamps to tighten the plate around the bar. You might have to experiment with different parts.
rcleaver
Fairfax Station VA
That might work better if you heat the strips after attaching them.
If you had a wider sheet of aluminum, it might be a whole lot easier (or at least a better result) with an English wheel.
jsaw
Geneva, N.Y.
Did you mean that they were .050"thick?
You could find someone with a sheet metal bending brake, & make a series of slight bends across the width of the pieces,or
You could find a piece of tubing the same size as your roll bar, clamp the pieces to it, and slowly Bump & massage the pieces & form them to the tubing.
Uncle Buck
Kansas
Find a sheet metal shop with a roll press. Then again perhaps I am wrong, can they roll material that tightly?
How about this get your hands on a piece of pipe that has the same internal dimension as the external dimension of your roll cage. Cut the piece of pipe you will use as a top die in half length wise. Now you need some sort of fixture or jig to hold a piece of pipe the same size as your roll cage (your bottom die). Then load the pipe like the rollcage(bottom die) in the fixture and compress one half of your split pipe (top die) on top of the roll cage diameter pipe and sandwich the material you want to compress between the two. I don't know from here if you have a shop with a press bend them up for you or you try it with a sledge yourself or what, but it is a start for ya. I am sure this could easily work, it is just like dies in a press.
WH0DAMAN
Oregon
Sounds like it will work to me. :beer:
senlow
Wheat Ridge, Colorado
A slip roll leaves a short straight section at each end of the part. Is that 1-3/4" tubing? Most slip rolls will not roll that tight.
When I worked with sheet metal, we made many small bends in 1/16" to 1/8" increments to approximate a radius. You could make a punch and die (as mentioned above) and press form the radius. Keep in mind that you will need to use a slightly smaller radius on the punch and die set to account for spring back.
Of course, you could also hammer form the radius over a pipe. I suggest this as a last resort because without alot of practice, it is hard to do a good job.
How do you plan to attach the aluminum? I prefer not to drill any unnecessary holes in a cage.
V
Vernmotor
Mt.vernon oh
Thanks Guys...I have found that A.R.T sells them for 32.00 ?..I will mess around alittle and see if I can bend them..if not 32 bucks ain't much..
Jim M.
DFW Texas
If all you want to do is protect the rollbar from scratches, then why not put some aluminum or stainless steel tape over the rollbar. You'll be done in 15 minutes and for a lot less money.
Jim M.
franksinatra
Minnesota
I thought of a couple of ideas. One, fasten the piece your trying to bend with 2 rivets lengthwise on the same size bar your trying to apply the piece too. Take it to the beach, lay down a towel on the sand. Beat the back of the pipe with the SS side down and it may form correctly with some persuasion. I would say you should smooth a section of sand to start out.
Second idea, get some SS and have someone bend it first and then cut it out.
I dont know if either will work, just some ideas. G:beer:
franksinatra
Minnesota
I suppose I should have added that you will need to drill out the rivets on the first idea and use the same holes to mount the piece on the actual bar its going on. G
V
Vernmotor
Mt.vernon oh
Just to update I need to take pics and I will..but the trick was to get the right alum..Guy call it 0-temper ?? All I know is it is soft and .050 thick ..I bend it around some tube the same size and a peice smaller..work good, Frank I like your idea..I might of try'ed that..Thanks to all for the help.
racer7x
Not sure what you are doing with the car but another option is use roll bar padding instead of the alum. Might be a little easier on the knees and elbows.
V
Vernmotor
Mt.vernon oh
I had roll bar padding in all my race car..it looks real bad after about 2 months..We do have to have it around the driver..put new on every year...
V
Vernmotor
Mt.vernon oh
Here is a update pic..got it done .tie-wraps holding in place while I am working on car.. when done I need to do some paint work and then I will fasten them on.
914forme
North of Dayton, Ohio
Clear plastic is the only way togo, you know the stuff 3m and others sell for paint protection. BTW, a metal edge on a roll bar could be like a knife to your race suit.
rinny_tin_tin
Northern Virginia
Not to avoid your question - however, have you considered coating the roll bars with that Linex bed coating - or even that Rhino - stuff - They are UV resistant and super super tough
VDubJoe
New Port Richey , Fl
If you want it more workable use a torch to aneal it. Use a sooty flame and cover it with soot. Then heat enough to burn the soot off. It should be very workable.
Joe
rodknocker
Rochester,NY
My 2 cents, if you bought some angle iron, I'm guessing around 2"X2", weld some tabs to hold the metal in place,weld the angle to a plate, then use a bar to push it into the angle might give you the shape.
