True or false
A_Pmech
IL
Is their a electric motor that can run on 3ph and single ph ? I was told their was but dont think so.
The motor itself? None that I'm aware of.
However, many motor drives can operate a 3-phase motor on 3-phase or 1-phase input power.
zmaxmotorsports
South of omaha
Not that I know of motor wise,but theres been times in the past where we just used 2 of the 3 wires on a 3 phase disconect to run single phase 240v equipment.
Single phase 240v welders run really good off 277.
larry_g
oregon
Once started a 3 phase motor will run single phase, at a reduced power from the nameplate. That is how some of the static 3 phase converters work.
lg
no neat sig line
rlitman
Long Island
They will run, but will run very hot. Running a 3 phase motor on less than 3 phases will eventually ruin the motor.
Gary S
Bismarck, ND
Every time I've had a 3 phase motor lose a phase while running, it dropped the breaker in a few seconds to protect it. If it is properly protected, the fuses or breaker will prevent the motor from burning up.
gregtwojeeps
Ky
False, that is why its called "single phasing" and will eventually cook the 3 ph. motor if the thermals do not trip out on the starter. I put 3 phase monitor relays on all my 10 HP + 3 ph. motor control circuits just to protect them from single phasing.
Norcal
A 3Ø motor will not start on single phase, static phase converters start a 3Ø motor & afterwards they run single phase, not good IMO.
larry_g
oregon
This is what you don't want to happen with a 3 phase motor.
It will burn out one of the windings in the motor
Don't tell all the home hobbiest running industrial machines successfully on static converters. The key is to run at a reduced load. When in the plant running 3 phase at near FLA and losing a phase =trouble.
lg
no neat sig line
wyliesdiesels
Modesto, CA
Yup because the overloads/thermals were set/sized correctly. Ive had to replace motors that burnt up because the overloads were set too high and didnt trip when the motor lost a phase in the feeder!
2mJps
north central Mo
I ask this because i was ask to look at a Hyd pump that was ordered to be run on single PH. Some one said it was made to run on ether but i did not talk to that guy and alot of the story was left out. I told them it was 3PH and it would not run on single ph.
wyliesdiesels
Modesto, CA
Is the pump single phase or 3 phase? If the pump is single phase and the service is 3 phase then that will work fine! But vice versa WILL NOT(3 phase pump on single phase service!)
larry_g
oregon
I don't know if the technology is being used in hydraulics but it is being used in water well pumps. http://www.aquascience.net/goulds-propak/ Well pumps that are touted in the link as constant pressure pumps are in reality a VFD that controls the speed of a 3 phase pump. It could be used in hydraulics as well but I have never seen it.
As an aside I have one of constant pressure pumps and I like it. One of the unforeseen advantages is that it is perty easy to run the pump on a generator as it has no inrush start-up current spike and will run at a couple of amps if only using low flows like the water taps in the house.
lg
no neat sig line
wyliesdiesels
Modesto, CA
lg
no neat sig line
^+1. Yup, Ive installed many water pumps with VFDs, on both 3 phase and single phase service. I dont see why a hydraulic pump couldnt be run off of a VFD as well...
