Hello, this is my first post, but have lurked for some time now, so hello. My garage/shop is 175' from my house, it was built around 1980 or so. It has a small panel in the detached garage fed off the 200 amp panel in the house. Wire connecting the two has three conductor of 2 gauge. 50 amp breaker in the main panel and no main disconnect in the detached garage. I am making my garage bigger and want to upgrade to include a small plasma cutter and mig, separate 20 amp 110V outlet circuits and light circuits two. I will run a 5kw electrical space heater too. The existing panel has no ground rod outside the garage and the neutrals and grounding wires terminate on the same bar.
Questions are can I upgrade to a newer panel without running a separate grounding wire back to the main panel? This would be mostly impossible to do. If I can upgrade to a new modern sub panel, do I drive a separate ground rod at the garage and bond the panel to the ground rod and unbond the neutral and grounding wires from each circuit? I have read many threads on the search and it seems everything changed in 2008, and I'm confused as to what will be right and what will work safely.
Thanks in advance.
Thanks in advance.
