1/4" drive square head screwdriver.![]()
Snap on N6700
Snap on N6700
that would be too easy........MT is usually for test equipment.
skyline, is it a square tip? maybe a double d for CCC carbs?
It is a birth defect that happens in 1 out of 10 million births of pliers. I believe that there is a hospital in Texas that specializes in separating the conjoined twin pliers. The surgery isn't going to be cheap, however, if successful, those pliers will go on to live a normal and productive life in society. Their life expectancy should be that of a regular pliers....
Sorry for the bad picture...but it's not square at all on the end. Here's a better picture:
hholmberg
You're right on the 1/4" drive, but the business end is not sharp at all.
Here is another one: Model B-3411. 9/16 x 1/2 wrench jointed on both ends.
MT150 is a "glow-plug hole cleaner" (???). See here: http://www.oliverdiesel.com/images/mt480/manual/partslist1.pdf
Edit: It is part of MT480 - Diesel Timing Meter
nice job. cool
Thanks! My adolescence coinciding with the establishment and subsequent blossoming of the internet left me with formidable googling talents, particularly for the search term 'hole'....![]()
pretty sure that wrench is used for GUAR
Snap on N6700
the 9473 is probably a drain plug socket. If its a 11/16 its for a Hudson , used to hold and turn the drain plug on fluid clutches.
Don't know, but they should still make them! I'd buy them, they'd be really handy in a tight spot.
Nice design, like it alot.
