So I have this intention of optimizing my time making things, and every fall, these things fall off of the trees in my yard and at a tremendous volume.
I've been toying around with the idea of making a 3pt tractor mounted PTO driven leaf vacuum since I have access to a water jet and some cool tools and they are relatively simple. BUT I scored an actual leaf loader for $75 - with an engine and solid duct/chute.
I started taking it apart and cleaning it up. It had some nice varnish in the tank, so I emptied it out and put it some new gas. Cranked it up with my drill and she started right away. Changed the oil/filter/plugs, gas and air filter. She purrs like a kitten - until I revved it up - sounds like a mini chopper.
All was good and then it started rattling like crazy when I revved it up. I thought it was going to be the motor as it was hard to isolate, but I pulled the impeller off and found out how bad it was out of balance and contacting the chute.
Two of the impeller blades are cracked and the outside of these corners are dropping into the chute making a lot of bad racket.
The worst corner drops about 3/8"...
I could buy a new impeller, but I'm sure they go for 300$ minimum.
So I can either make a new impeller, the shaft coupler is heavy duty and I could waterjet out a square and the blades easily - maybe even change the design a little bit, add some teeth to the blades, weld it, and balance it.
But then I figured, shoot for what I have into it and I still have to buy a hose, I wondered if I could slice out the crack and straighten the plate in a little bottle jack HF press? Think I'd have any luck?
There's also a local straightening shop and I was thinking about dropping it off there.
Hmm...
Can't wait to destroy those leaves!!! Got plans to mount it on a trailer or build a 3pt dump bin.
Hmm...
