INVERTERS/ and power cords
PEARL
i bought a 2000W/4000W inverter to run my refrig or small a/c during storms.
first problem: it would only run a fan or a light...
after much internet research and calling harbor freight for advice. (they were no help) i found no answer.
solution: i asked one of the guys who runs his tools from his truck and he said ...oh u have to use a marine battery.
second problem: borrowed a marine battery from my brother, and inverter would not run anything off of medium duty extension cord.
solution: plugged portable ac directly into inverter. inverter struggled and almost tripped but did not.
now my friends out there in cyber world...am wondering if i have a lemon inverter or if i need a heavy duty extension cord? if so, what gauge and where to get it.
i have to run the inverter 50 ft away from my refrig or room a/c
ps. the guy who suggested an inverter for storms says he has had no problems with his inverter. he can run a small room ac and his refrigerator.
thanks, pearl
where2
South FL
What are you using for power cables for said inverter? The power cables necessary to pull energy out of a 12v battery and make 120vAC out of it need to be HUGE, as in about the size around of your thumb. Also, please provide us an idea of the Ah rating of the battery you are using.
My Heart Interface Freedom 20 (2000W) inverter in the garage came with two 2/0 AWG cables about 6' long. A reasonably decent setup for batteries is four 6v golf cart batteries wired in a series + parallel combination to create a 12V, 650Ah battery bank (from 6v, 325Ah batteries).
HOTFR8
Castlemaine, Victoria. The Hot Rod Centre of Austr
What size is the inverter again ? It may be the issue and not the power cord. I have what I call a UPS system (as it runs even if the other systems fail) as I am running the computer, fax machine, phones etc. (my office basically) as well as many other items here on mine right now. Two 6 volt batteries charge from two solar panels and from the main supply via a battery tender connected to the bigger solar system that also feeds back to the grid.
Gary S
Bismarck, ND
4000 watts on 120v is 33amps. 4000 watts at 12 volts is 333amps. Is your wire up to that?
And, a refrigerator like any motor needs likely 3x that when starting up the compressor, so can the inverter and wire deliver 99amps at 120v and 1000amps at 12 volts for startup?
G_P
Central CT
An inverter of that size is going to draw huge amounts of power from the battery. You need to have it hooked to the battery of a running car or a large battery bank.
Hell my 600w UPS has 2 40a fuses. Testing it with a different battery I melted a pair of 12ga jumper wires.
Sent via carrier pigeon
theoldwizard1
SE MI
Most inverters are designed to protect themselves. They will automatically shutdown when the input voltage drops below about 11.0V (some kick out at 11.5V). Unless you have a truly fully charged battery (approximately 13.2V without load) AND the proper size wire.
The proper size wire depends on length and just how much power you are running through it. 6 gauge jumper cables are rated at 250A, but that is for a very short period of time. For continuous power, I would not want to draw more than about 50A through 6 gauge.
2ManyProjects
First things first: EXACTLY what inverter did you buy? We need at least the make & model to do more than take wild guesses at its true capabilities; a link to the manufacturer's product page would also be helpful.
"Harbor Freight"? That does not bode well; but I'll reserve final judgement until I see the specs.
"Marine", per se, has absolutely nothing to do with it. What you need for inverter applications is a high-capacity DEEP CYCLE battery bank -- with emphasis on the "high-capacity" part: If that "2000W/4000W" claim is even close to accurate, NO single battery (save for maybe a huge Group 8D model; and even that would surely peter out in well less than an hour at full load) is going to be anywhere near enough.
For a variety of reasons that I don't need to belabor at the moment, an air conditioner is a VERY difficult load for an inverter/battery setup. Awhile back, I developed plans to put such a system on my boat (plans which are now on hold due to other more pressing projects, like fixing my Sandy-damaged shore home), in place of an auxiliary genset. I determined that to have any hope of running the relatively small (~12K BTU) marine HVAC system overnight, I'd need at least 1,200 Amp-Hours (@ 12V DC) of battery capacity; and even that might prove inadequate on a really hot night, when the duty cycle of the A/C would likely be higher than my target 30-50%. Your single "marine battery" doesn't stand a chance in that context.
Well... You did mention Harbor Freight. I would certainly NOT expect top quality from anything purchased there.
If you mean the extension cord used to connect the (120V AC) load to the inverter, the ideal answer is to use NO extension cord at all. And if you must use one, it should be as heavy as possible (for a 120V air conditioner, I would guess at least AWG 12; perhaps even heavier if the run is more than a few feet).
HOWEVER... In all probability, voltage drop on the load side is the LEAST of your problems. You near-certainly have a grossly inadequate battery bank feeding the inverter, and are probably using FAR too thin (and/or far too long) cables to make THOSE connections (even relatively small amounts of voltage drop on the input side of the inverter will absolutely KILL you).
Just for purposes of illustration...
If we presume that "2000W/4000W" designation represents the load capacity of the inverter on a continuous/surge basis, and that the inverter runs at 85% efficiency (which is probably optimistic), you will need a CONTINUOUS source of almost 200 Amps at 12V DC. Even a rather good Group 31 "Marine" battery (such as, just for example, http://www.sears.com/diehard-platinum-marine-battery-group-size-31m-price/p-02850131000P) will be rated at no more than approximately 100 Amp-Hours. But critically, this rating is at a "20-HOUR DISCHARGE RATE", meaning that the load is deliberately limited to that which the battery can constantly support for at least 20 hours (which in this case would be about five amps). The reason this is significant is, due to Peukert's Law (cf. http://en.wikipedia.org/wiki/Peukert's_law), the total capacity of that battery will be DRASTICALLY diminished at faster discharge rates. If you shorten that discharge cycle to, say, ten hours, you'll lose perhaps 20-30% of your total battery capacity (i.e., it's now effectively only a 70-80 Amp-Hour battery); and the more load you put on the battery, the worse this degradation becomes.
So do the math: To keep the discharge rate down to a level that the batteries can cope with, and thus deliver their full rated capacity, you would need AT LEAST 40 such batteries, assuming the inverter is fully loaded.
The short answer is, "You don't." You're expecting WAY too much out of one wimpy little battery and a cheap-*** inverter.
The refrigerator by itself MIGHT be "do-able", with a semi-practical battery bank, if it's not too large or too "ambitious" a refrigerator; but both the refer AND an air conditioner? Naaaahhh.
So what inverter -- and more importantly, what batteries and what cables -- is HE using?
where2
South FL
^^^^^ I love the GJ electrical forum. :thumbup:
I'm sure it's Item # 95596 or 60432 or 69662. They're all on special for $129.99 with a coupon this month. ;)
We also didn't get any specifications on this "room A/C". It might be a 15,000btu unit for all we know. There were no suggested wattages for A/C units in the manual.
The inverter manual for a 69662 indicates it has eight 30A blade fuses inside it. I'm guessing those are all in parallel on the input side. The instructions say: "Connect all batteries together using cables of the thickness recommended in the specifications sheet, or thicker". Specifications (on page 5) call for no less than 2 AWG when using 6" or shorter leads, or a 00 AWG or thicker for 10' leads.
Fifty
Yamhill, OR
No way in hell you are going to run an A/C off just a battery. Save yourself a bunch of trouble and stop now. In order to make that work you will need at least 2-4 deep cycle batteries in parallel to absorb the power surge, and even then, you still need to be hooked up to a car or something else that will feed many hundreds of amps back into the battery while you are using it. Otherwise the run time will be counted in minutes, if you can get it to start at all. Even a normal car with a normal alternator at idle would not be even half enough.
Sureshot
Bridge Creek, OK
A quality 3000W invertor generator. Honda, Yamaha, etc is what it will take depending on the AC Unit.
Running an invertor like that may be ok on a truck for tool usage etc but for what you want is not realistic. **** it up and live without AC and leave the fridge door shut.
Storms are forecast well in advance. Invest in a quality cooler and find a supplier of dry ice. Far simpler and economical.
laser3kw
northen IL
the sample manual states "batteries" - plural - more than one.
Also "8 - 30amp fuses"? hint , hint?
2ManyProjects
1 Post question that seems kind of sketchy. Trolling perhaps?
Could well be. And the fact that he's not been back since posting the initial query further reinforces that impression. But my initial inclination is (at least usually) to grant the benefit of the doubt, and attempt a serious answer; if nothing else, someone else reading the thread may benefit.
P
PEARL
Thanks to all replies. Seems I need more detail:
Items used:
Chicago Electric model 92464 (harbor Freight)
Auto Shut Down
Modified Sine wave
2000W/ 4000w surge capacity
Input 11-15VDC
overvoltage shut off @15VDC
Current draw: < 0.2 amps
AC and refrigerator were not tried at same time.
Portable AC: AC ran when connected directly to converter, but power seemed to be "struggling"
620W
120V
6 amp
60Hz
Refrigerator: Cool positions were in the Zero position when i tried to run it and Inverter tripped before i could turn it Refrig. on.
115V
8.5Amp
978 W (V x A)
60Hz
Connection:
Batteries connected :
(pos to pos to pos and neg to neg to neg)
2003 Saturn SUV battery
6ft 4 Gauge Battery cable with claws (multi strand copper wires)
Marine battery (no other details except it had two posts on each side)
6ft 4 Gauge Battery cable with claws (multi strand)
Inverter
Outdoor extension cord 30ft size 16/3
why doesn't it work...seems to me it should......
what is the verdict?
Pearl
laser3kw
northen IL
all other post's asside - 16/3 is way to small. try a "commerial use", "industrial", "contractor" type cord, the bigger (and shorter) the better.
P
PEARL
Seems i need to give more detail.........
Oppps......am wondering if i posted a reply or not....i did something....sigh sigh.....
anyway, if i didn't post, here goes again...
sorry, not familiar with how to use these boards....mea culpa....
Problem:
Inverter won't run anything more than lamp or fan.
I want to use it for storms/hurricanes for the inevitable power outages.
am sick of leaving for a week because of no power and 3 cars filled up is a lot better than a noisy generator and/or no gas.........
Equipment used:
Chicago Electric inverter: (harbor freight) fuses were checked.
2000w w/4000W surge capacity
auto shut down
Modified Sine Wave
Overvoltage shutdown @ 15 vdc
Jumper cables: 4 gauge 6ft clawed (multi strand; not one wire)
Outdoor extension: 16/3 approx: 30ft
Refrigerator:
115V
8.5 amp
60Hz
Portable a/c
120 V
620 W
6 Amp
60 Hz
Connnection:
2003 Saturn SUV car battery (running)
jumper cables
2 posted Marine Battery ( i seperated the sets of jumper cables one connection on each post)
jumper cables
Inverter
outdoor extension cord.
* The a/c worked when plugged in directly to inverter but seemed to struggle
* the refrigerator was placed in "zero" position and the inverter tripped before i turned the refrig on.
only thing i can think of is that i need to do something with the size and quality of wires?????
what's the verdict?
thanks
Pearl
Charles (in GA)
50 mi south of Atlanta
16/3 cord will not work a fridge or a A/C unit properly. You need at least a 14/3 and much more preferred is a 12/3 to keep voltage losses at a minimum.
The two batteries are marginal at best, and using jumper cables......... the clamps barely make contact, just on the tips of the teeth, plus the wire itself is too small.
Charles
CNGsaves
KS and OK
Questions for OP:
How old are you??
What country are you in??
Why can't you buy a GENERATOR for your backup power needs??
Fifty
Yamhill, OR
I repeat: not going to work!! :lol_hitti
A 620w air conditioner will pull approximately 62 amps from your battery when running with nothing else! Your saturn at idle might put out 40 useable amps. Your battery is less than 100 amp hours. Do you see the problem?
Now you want to add more than an air conditioner? I REPEAT: NOT GOING TO WORK!!!
IF: You add four large deep cycle batteries, and a 300 amp alternator to your Saturn, it might work, for a little while. Expect to spend over $1,000.
theoldwizard1
SE MI
@PEARL - In theory, it should work, assuming you have a big enough battery (see Fifty's last post).
Go back to HF. Buy their cheap digital volt meter. Connect it across the battery. Start the inverter. Plug in a 100W incandescent light bulb. Check the voltage. Plug in another one and check the voltage. Repeat. I'll bet by the time you get 5 or 6 plugged in the battery voltage will be down to about 11.0V and the inverter will shut off to protect itself.
Like I said, it MIGHT work if you had enough batteries ! Also, using a regular car battery to run an inverter is a good way to kill that battery quickly. You need (likely 3-4) deep discharge batteries. Deep discharge batteries are rated at how much current they can supply for a length of time. They i=usually test at 2 time lengths, 20 hours and 100 hours. You want one rated for at least 150A for which ever period of time is appropriate for you. I hope you have a lot of $,$$$ !
P
PEARL
1. to all who answered without rolling eyes and shaking heads, thanks....
2. to the person thinking i was "trolling." what the heck does that comment mean?
3. now i remember why i don't try these types of boards. some of y'all are down right nasty. as was the first board i used inquiring about a linux operating system...
4. if you asked me a question regarding my profession, Pharmacist, and i answered you like you were a dimwit, how would you feel?
5. To Fifty: why does an small room AC say SIX AMPS on the back and you are telling me it would pull 62 amps? (i do like your lil icons...the icons i would like to use for some of you are not commercially available..hahahahaah)
5. i am sixty one year old single female living in new orleans, la, USA and am trying to find an alternative to dragging gallons of gas around.... if any of you had lived through a storm like Katrina or Sandy you would know why i don't want to use a generator......In case you can't figure it out...NO GAS!!!!!! and total home natural gas generators are too much money for a "just in case" scenario......AND when water gets in the GAS lines they mess up anything attached to them.....been there done that!!!!!!!!!
6. as my mechanic says, "let's fire up the pig." and when i get this lil piggy fired up,
i will return and give all the nasties this lil icon. :)~
7. SHEESH people
walrus
Maine
Someone mentioned a Honda inverter/generator, get a 2000 or 3000 watt one and be done with it. Too small an inverter plays hell on electrical stuff. Get a couple of gas cans, fill them before a hurricane comes, if you don';t need it put it in your car afterwards
bfarroo
Green Bay WI
The input current of the ac unit is 6.2 amps at 120v when you drop down to 12 volts assuming the inverter is 100% efficient the load on the battery is 62amps. For a little bit of reading you could do a search on Ohms Law and it will explain what is stated above. By the time you purchase enough batteries and solar panels to keep your system running while the power is out your going to spend thousands of dollars. Look at getting a small inverter generator and keep 10 gallons of gas on hand. They are the most efficient generators out there and most will run 10+hours at 50%load on 1 gallon of gas. Running the generator for an hour every 3 hours would probably be enough to keep your fridge/freezer cold enough so that your food doesn't spoil.
Stuart in MN
Minneapolis
The problem with those kinds of small inverters is they generally aren't going to work well with appliances that have a high startup current - mainly, things with motors like refrigerators and air conditioners.
theoldwizard1
SE MI
There is no easy or cheap solution to your problem.
In all seriousness,
  1. move to a place that does not have hurricanes or tornadoes or blizzards
  2. buy a camper and a truck to pull it and leave town early.
Sureshot
Bridge Creek, OK
You will need a peddle bike rigged with an alternator to recharge the battery to run the fridge every few hours. Great way to keep the food cold and lose a few pounds.
I still think a top notch cooler and dry ice or small invertor gen.
theoldwizard1
SE MI
In all seriousness,
Keep it nice people. The lady is only asking for help with something that she does not know much about.
Okay
Don't worry. Be happy! :lol: :beer2:
There really is nothing you can do without spending a lot of money.
2ManyProjects
Items used:
Auto Shut Down
Modified Sine wave
OK, there's your first problem (of several). "Modified Sine Wave" is a marketing euphemism for "glorified square wave"; it only vaguely resembles the TRUE Sine Wave power that is THE standard for AC power distribution throughout the world. Here is a graphic representation of the difference between these two waveforms:
El-cheapo inverters use "Modified Sine Wave" because it is cheap and easy to implement. But many devices designed to run on sine-wave AC power (particularly devices with motors and similar) do NOT like it at all.
Inverters which produce true sine wave output ARE available; but you aren't going to buy one for $129. Here is an example of a QUALITY 2,000-watt 12V/120V inverter:
http://www.mastervolt.us/marine/products/mass-sine-12v/mass-sine-12-2000-120v-60hz/
But sit down before you check the price tag. :shocking:
Given the "parentage" of this unit, it would be prudent to "derate" that significantly. Cutting those numbers in half might be a good starting point.
Input 11-15VDC
As "theoldwizard1" pointed out, there is almost certainly an UNDERvoltage shut-off as well. But even if there isn't, feeding the inverter with inadequate voltage will surely produce inadequate (read: "unusable") output anyway; so it boils down to the same thing.
Note that this is obviously just the IDLING current (i.e., with ZERO load on the inverter).
Even so, it's near-certain that either one is "too much" for your battery/inverter setup.
620W
120V
6 amp
60Hz
I'm not surprised that it was "struggling". First, because of the non-sinewave input, secondly because the input voltage was almost certainly inadequate, especially during the start-up cycle (when the unit can be expected to briefly draw several times its normal "running" current).
115V
8.5Amp
978 W (V x A)
60Hz
Again, this is surely because you were overloading the battery/inverter rig severely, especially during the start-up cycle.
Connection:
Let me guess... Probably rated at somewhere between 50-75 Amp-Hours. As explained previously, that's nowhere near enough.
Not even close to good enough. Even the rather "optimistic" recommendations in the manual for your inverter call for AWG 2 battery cables; and they should be absolutely as short as possible (yes, even six feet IS significant in this context). And the additional series resistance imposed by the crappy contact between those "jumper cable" clamps and the battery posts only exacerbates the situation.
By way of comparison: If I were attempting to set up such a rig, I'd probably use 1/0 or 2/0 for the inter-battery connections (each of which would be measured in INCHES), and at least 4/0 (maybe doubled-up 4/0) for the main connections to the inverter.
Possibly a bit larger than your Saturn battery; but still surely inadequate (by a country mile, as the saying goes).
And again, not even close to good enough.
As alluded to earlier, this wasn't your biggest problem; but it wasn't helping, either. Earlier, you said "medium duty extension cord". FWIW, I would not call a 30-foot AWG 16 cord "medium duty". Depending on whose formula (or more specifically, whose resistivity constant) you care to use, as little as 12 amps through that cord would be enough to produce the maximum recommended (3%) voltage drop between the source and the load. And even that presumes full voltage at the source, which you near-certainly did NOT have.
See above.
Your earlier post DID come though. So no need to address this repeated information.
Actually, by the time you consider inverter losses and the fact that she's dragging down the batteries insanely fast, that "6 Amp" air conditioner is very probably pulling at least 70-75 Amps out of the batteries once it's up and running. The start-up current is surely in the HUNDREDS of amps.
"Pearl" does seem to be a bit math-challenged.
Agreed. As I posted earlier, it's going to take a MUCH larger battery bank (and very probably a much better-quality inverter).
Four Group 8D batteries (at about 250 A-H each) MIGHT be enough to get this going, and keep it going for long enough to be marginally worthwhile. Four "normal"-sized automotive or marine batteries won't stand a chance.
[The BBS software is nattering at me that the message is too long. So I'm breaking it here. Continued in next message...]
2ManyProjects
[...Continued from previous message.]
http://en.wikipedia.org/wiki/Troll_(Internet)
I'm willing to take it at face value that you were not "trolling". But you need to lose the attitude when asking others for help. Your question WAS ludicrous enough (at least in technical terms) on its face to arouse at least some suspicion.
Basic arithmetic.
As you yourself noted, Watts = Volts * Amps. (That's an oversimplification, as it ignores the case of reactive loads, such as motors, where Volt-Amps and Watts can be significantly divergent at different times; but for now, it's close enough.)
That "small room AC" was designed and intended to run off normal house current (120V AC, 60Hz -- and notably, SINE WAVE). So that six amps at 120V AC represents (approximately) 720 Watts.
But to get 720 watts at 12 volts requires SIXTY amps. And even that assumes NOTHING is lost in the conversion process (which is unrealistic; typical inverter efficiencies run from about 70% to perhaps 90%, depending on several different variables).
I (and many of my friends and neighbors) DID live through Sandy, thank you. We have still not recovered; tho' thankfully, the losses were only material in nature, not human.
For that application, a standby generator really is the only practical solution. Be it large enough to power the whole house, or only selected critical loads, the principle is the same. If you don't want to deal with gasoline (and I agree it's best avoided, for all sorts of reasons), use either Natural Gas (if it is available in your location) or LPG/propane. Regardless of the type of fuel, if you're keeping it on-site, you need to store enough of it to carry you through the longest expected power outage. That will surely mean a fairly large tank, which in turn will need to be permanently installed. And since the tank needs to be permanently installed, there's no good reason to NOT permanently install the generator.
Here is just one example of a very reasonably priced standby generator which would surely be large enough for all of your truly critical loads:
http://www.generac.com/Residential/CorePowerSeries/7kW/
http://www.homedepot.com/p/Generac-...or-with-50-Amp-Transfer-Switch-5837/202214401
Note that even presuming you paid a pro to do a turn-key installation of both the genset AND a several-hundred-gallon propane tank, this would be still be VASTLY less expensive (both to purchase and to maintain) than implementing a battery/inverter system which could really do what you want.
Kevin C
Portland OR
The reason I asked if was a troll post is based on seeing lots of people that ask a single question that seems a bit out there and are never seen again.
I have answered a few myself.... Never hurts to see if the OP actually comes back.
This may not be the best place to get the info your looking for. A forum that specializes in off grid may have a bit more experience with what your trying to do. This is primarily a garage forum, lots of good people but the focus is a little different. Still, lots of good answers.
http://www.donrowe.com/inverters/inverters.html
http://www.donrowe.com/inverters/article_emergency_backup_power.html
http://www.donrowe.com/inverters/inverter_faq.html#emergency
I like the last link....
I attached a couple of links that might help.
Fifty
Yamhill, OR
I don't think anybody is not being nice. We said it won't work. We explained why. Then we explained why in different ways. The answer is still the same. What else can we say? It simply won't work. Batteries are not a replacement for liquid dinosaur fuel, that's why electric cars still have not taken off.
CNGsaves
KS and OK
OP . . . . your inverter WILL be useful, but not for A/C and frig but for something small like your laptop computer, fan, recharging your phone, cable modem/router for landline phone on VOIP (MagicJack, Vonage, etc.)
Here's your solutution for BIGGER electrical needs - - - - timing is pretty good as most in New Orleans may be getting rid of extra generators they bought back when hurricane hit (ie believing that they are safe now).
6000 watt generator $380
http://neworleans.craigslist.org/tls/4074237489.html
LPG tanks - - - 20 lb and 30 lb - - - $18 and $35
http://neworleans.craigslist.org/tls/4092828263.html
Tri-fuel kit $187
http://www.propane-generators.com/tri-fuel_kits.htm
With the above setup, you can run on one of 3 fuels (gasoline, natural gas, or propane/LPG).
I would recommend Natural Gas as a semi-permanent setup like you would an outdoor BBQ grill. Then if your NG went out (unlikely for minor outage, but possible), then couple changes on regulator attached to generator would allow you to change hoses, and run on LPG/propane bottles you had stored for emergency fuel.
If you've got outdoor utility shed, it would be good place to store generator. Bring it out of shed when needed, and connect to NG supply with flexible line.
Good luck. GJer's indeed ARE trying to help, but best solution needs something realistic that will work.
HOTFR8
Well the OP has not liked some of the comments in response and that is why I made the comment. Some posts have gone over as rude and to some one looking and asking for some help with some thing she is trying to learn about.
With any system (I have two Solar Sytems here) you have to calculate what you want it to do.
theoldwizard1
SE MI
I just found a real solution !
A complete system, inverter, reasonably sized battery and a solar panel ! It is called a SUNRNR (sun runner) 110 - $3,800.
One solar panel is included, the wind generator is optional. You can add extra solar panels and extra battery banks.
It will run a small (like Pearl's) A/C for awhile (2+ hours). The problem would be recharging the battery. It would take more than 1 or 2 solar panels ! In theory, 5 panels would run the A/C, as long as the sun was shinning.
2ManyProjects
Your tongue IS firmly planted in your cheek, right?
That is wildly optimistic, at best. The standard battery they show for that package is a single Group 8D AGM type, rated at 245 Amp-Hours (20-Hour Rate). As previously established, Pearl's "small room AC" will be pulling at least 70-75 Amps, just for normal running; the start-up surge will be several times that. Further, as you are hopefully aware, AGM batteries should NEVER be discharged more than 50%, if you want to get any sort of decent life out of them; limiting the discharges to 30-40% will pay huge dividends in the long term. And let's not forget Peukert's law.
All told, you're probably looking at about an hour of "safe" run-time per (Group 8D) battery. How long was the power out after Katrina? How big is that battery-storage shed?
Well, that's another problem, for sure.
MANY more.
Nope. That "140 Watt" figure claimed for the panel is at best a marketing-driven "ideal value", which will virtually never be achieved in real life. Maybe in Tuscon, AZ you could get the sort of consistent "bright sunlight" required to hit that figure (sometimes, maybe, on a good day); but not in New Orleans, or most anywhere else in the country.
The mother of all "Bottom Lines" with regard to both this specific suggestion and the thread as a whole, is...
EDIT: I just noticed yet another problem. Direct quote from their "Technical Specifications" page http://www.sunrnr.com/Specification_Technical.html:
Modified sine wave output (pure sine available on request, but expensive)
I'll give 'em points for understatement, at least. :rolleyes2
theoldwizard1
SE MI
Not really. Admittedly did not read all of the technical specifications.
  • Why didn't they use a flooded cell battery (probably because they can't ship them, at least with the acid in the battery). Requires a bit more maintenance, but overall more "robust".
  • Yeah, modified sine wave is far from the best. For that kind of money, I was assuming it was a true sine wave.
I would not be so pessimistic about the sun in New Orleans. I don't have the talent to calculate power from the sun there and I'm sure there are better solar panels out there.
You can buy a Outback inverter/chargee, VFX2812, true sine wave, 2800VA continuous, for under $2,000. Of course you need solar panels, a charge controller, and some serious batteries. Worse, you need some place to store all of this during the storm.
Sigh. You are correct.
There is no such things as a free (or even inexpensive) lunch !
