krdiesel03
Is anyone else rebuilding packs. I have rebuilt and sold about 20 so far, Not a huge profit, only $10 each. Was just seeing is anyone else was having any luck with this.
I rebuilt quite a few for my personal use.. Never had any issue.Is anyone else rebuilding packs. I have rebuilt and sold about 20 so far, Not a huge profit, only $10 each. Was just seeing is anyone else was having any luck with this.
So you really have nothing useful to contribute to this question?? Since you would clearly have zero experience with the subject matter..I use corded tools .....air or electric.....
the only battery powered ones are my tooth brush and vibrators for the girls.......but the standby for the girls is a corded Hitatchi
yup, never runs out of oats
where do you source your batteries? I have a few that need rebuilding.
How are you attaching the tabs?
I buy lots of 10 and just swap around the cells. I remove the cells with the tabs still on them.
Hi krdiesel. I rebuilt one of my NiCd packs recently, but I use new cells from ebay. No pics, but my rebuild looked virtually identical to what hofferwood posted above.That is correct, then running them through 3 cycles to verify operation
I'm sorry but I don't consider that rebuilding the pack and I hope you are honest in your ebay listing that these packs are not rebuilt with new cells. Cells fail for a few reasons but usually when one cell fails others aren't to far behind. All the rebuilders I have checked into use all brand new cells.
Thanks jacked. I thought I'd need something like that. Probably easier for me to stick with new cells with solder tabs then. I've got another pack I want to rebuild very soon.my brother does it and he's built some sort of spot welder. It uses some high value capacitors. Tacks the tabs right on to the batteries.
Sorry, but that's a "hack job"!!
If one or two cells are bad the others aren't far behind. The way to rebuild these packs is to replace all the cells.
Why would you do all this work and leave behind "walking wounded" cells??
I've done that on a couple occasions and ended up with a very short remaining life of the pack - never again!!
Ok, so not just swapping around cells from other dead drill packs then.These are tesla car pack pulls so the case is perfect
Yes I am being honest in the listing, I have not had any issues and I am offering a warranty on them.
With this cost of new cells and the cores even buying them in huge lots it is less expensive to buy new packs.
That looks like a fair deal. I see your description is "refurbished" not rebuilt, so you're definitely not misleading anyone. Sounds pretty fair to me.I am charging 29 for the packs and $5 for express shipping, these are the 1st gen lithium with the LED gauge.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=261303618824
I am charging 29 for the packs and $5 for express shipping, these are the 1st gen lithium with the LED gauge. Used packs are listed for $33 to $35, so I am running them through a testing machine and offering them for less than used.
I have 2 left and they will be the last ones. the cost of cores in the last month are running around $100 for 10 and only averaging 3 packs worth of cells a pack.
The circuit board is the battery management system (BMS). It'll prevent the battery from dipping too low in voltage (discharging), or too high (when charging). Some BMS will do more than others.
To convert, you will need the BMS. Lithium batteries are picky.
you can find cells on ebay.
You can not convert nicad to Lithium, I would think the ryobi would be the same as the craftsman.
