Jeff May
I added an addition onto my shop. The old section is being heated with an oil fired forced hot air furnace.
I need to run some type of ducting from the furnace to the addition.
It is about a 35' run.
My question is,
Has anyone ever used PVC pipe for hot air duct?
I was thinking of using 6" pvc from the furnace to the addition.
There is a partition between the addition and the old shop.
I was going to use the 6" for the main run and where it gets to the new section add a Y fitting and drop down to 4" and let it turn down and exit the 4" pvc through the ceiling of the addition.
Has anyone ever used pvc, or should I use something else?
I was thinking the pvc would be smooth, easy to work with and less expensive than regular duct work.
I'm open to ideas, thoughts and suggestions for this.
Many thanks,
Jeff
My question is,
Many thanks,
Jeff
