thesilverone
RLL is all you need
JB Welding the screws in?
I need to pick up some of this beloved "super lube."
I use super lube on all Snap-on ratchets. But I use the red assembly lube on MAC ratchets because the super lube will make them so they don't click anymore. MAC ratchets aren't sprung as heavy as Snap-on ratchets are, so they need a thinner lube.
This sounds like an example of over lubing a ratchet. If you are applying so much superlube that the spring in the pawl or other springs in the ratchet are becoming weak, you are using too much. A light, thin coating of superlube all over the inside of the ratchet should never stop the ratchet from clicking or keeping the selector in place.
All you should be doing is dipping the small acid brush in the superlube and brushing on 1 thin coat (think of painting) all over everything. This is enough grease to lube for a long time, but not interfere with spring tension in the pawl or anything else.
I am not saying there is anything wrong with using RLL but superlube should never actually cause a racthet to malfunction if it is applied properly.![]()
Just let is sit on a white paper towel for awhile. Haven't you ever pulled a Kotex out with your teeth?![]()
RLL (Red Lube of Love) = Permatex engine assembly lube.
Also has anyone tried any bicycle chain lube, for some reason this application is just screaming out for a couple of drops of Pedros.
Totally. As a bike mechanic I've usually got lots of "bike-specific" lives hanging around, and not much else. Steer WAY clear of any kind of "dry" or wax-based lubes, as they're only barely lives to begin with, and only clean up in alcohol or acetone. (Hence, Pedro's Road Rage is probably great, but not the other dry chain lubes.)
Also, any kind of polarized lubes are pretty rad. They cling like nothing else, and break down pretty slowly (on a dyno, anyway) compared even to Phil's Tenacious Oil (speaking of which, Phil's TO is great for some ratchets...). Bike lubes are expensive given the quantity you usually purchase, but they're generally very high quality.
I don't know bike chain lube, but if it's anything like aerosol drive chain lube I can't imagine it'd work very well. That stuff is tacky as all get out (more so than RLL).
the stickiest chain lube for bicycles is probably chain L or phil wood tenacious. these closely resemble bar and chain oil for a chain saw. the heavy wet lubes(finish line wet) are pretty close to 30wt oil, thick but not really sticky.
Before I posted this thread, my first thought was to use Tri Flow, which is a bike chain lube. But when I did a search, I found someone who said it was too thin for ratchets.
Thought about trying this:
Just put in Lucas Oil Assembly Lube. So far works the best. I have used both bicycle chain lube and air oil before. They work great as well.
