Battery Charger Poles
arturo7
huntington beach
I was given a battery charger that has no clips or markings on the cables. How can I determine which side is positive?
thanks
mech-tech
Hook a digital volt meter to it. If ya have the positive on the negative, then the meter will show a negative sign on the display.
RedBKM
Central Virginia
If you have an analog meter (Simpson 260 etc.) you wont see polarity. You can check each lead for a short to the case, if it's metal.
metaleltr
Western Ohio
What? Analog meters will indicate polarity.
This is the meter he referenced, which appears to show no signs of indication polarity.
andywander
The polarity indication consists of which way the needle moves.
If you hook it up backwards, the meter needle will be egged against the zero volts stop.
RedBKM
Central Virginia
We understand that but the OP might not. +12 or -12 wont appear and could confuse somebody. I've had to look twice at my 260 more than a few times.
Checking for a short to the case doesn't even require powering it up.
andywander
Well, I don't think we know what the OP understands or not-and I think it is good to explain it, like we have now done, instead of saying something that could easily be misunderstood, like analog meters don't indicate polarity.
And, what makes you think there will be a short to the case on either lead?
andywander
I just checked 2 different battery chargers.
The first has a plastic case, so neither lead is grounded to the case.
The second one shows infinite resistance between either the negative lead or the positive lead to the metal case. Interestingly, when I powered it up, I did read 14V between the red lead and the case.
