pauls340
By code we had to add seven smoke alarms and wire them with battery backups. Why do they chirp periodically? Drives the dog nuts
By code we had to add seven smoke alarms and wire them with battery backups. Why do they chirp periodically? Drives the dog nuts![]()
A side note... If you have a dog door, its pretty easy to train your dogs to go outside when the alarm goes off.
The obvious reason is that if you have a fire, the smoke and noise creates a lot of confusion. Most times pets will go and hide somewhere in the house. Training them to leave might save their lives.
The other is if your house is like mine, once in a while the alarm goes off from cooking. Its really funny to watch the dog evacuate the house and sit outside until you give them a treat and tell them to come in.
thats some good advice A side note... If you have a dog door, its pretty easy to train your dogs to go outside when the alarm goes off.
I know the subject is smoke detectors. Just asking.......
Are you sure they're not combination smoke and/or CO detectors?
CO detectors have a finite life of the CO sensor. I think about 7 years. When the time is up for the CO sensor life it will give a warning of some kind.
How big is your house that you needed 7 more? How many do you have total?
I'd likely wager that the batteries need replaced. False alarms are fact of life with detectors.
Thanks for all the 2cents, many will take advantage of the tips. We don't have a big house by any means. We like to say it takes an hour and 15 minutes to clean the whole thing. 1250 sqft ranch but in Michigan you have to have a detector in each bedroom, hallway and basement. Bought a box of 9volts today. Thanks![]()
I suspect small insects getting inside might have set mine off a few times. A couple have needed replacement at about 7 years old having started chirping.
