signcrafter
- Joined
- May 9, 2012
- Messages
- 12,365
This has been on my list of things to make for some time now after reading this post by mechanicnamedjohn, http://www.garagejournal.com/forum/showthread.php?t=91216. My list of things to do or make is pretty long and always seems to keep getting longer. A few months ago I finally bought the 400W party fogger for 25 bucks shipped from amazon, http://www.amazon.com/dp/B0006M59M6/?tag=atomicindus08-20. I've been picking up a few fittings here and there since then to put this thing together. Yesterday I was out and about and stopped by HF to pick up a regulator for the air hook up, http://www.harborfreight.com/150-psi-air-compressor-regulator-kit-with-gauge-68223.html. It was on sale for 4.49 and I had a 25% off coupon and a free screwdriver set coupon so got the regulator and screwdrivers for around 3.50. I will give the screwdrivers to the daughter to play with for now. I was a little leary of going with HF quality on something that you want to regulate pretty low but I will see how that works and will upgrade if I need to.
So I started putting things together yesterday. I had to take the machine apart to get the front nozzle cover off. Mine was spot welded, if you could call it that, instead of screwed on like in the amazon picture.
I unscrewed the brass nozzle and it was 1/8" male pipe threads on it. I bought an adapter to go from 1/8" to 1/4" since that is what the regulator is and I have more 1/4" fittings laying around then 1/8" fittings.
On the couple of DIY smoke machines pictured in MNJ's thread they have the Tee set up so that smoke machine goes straight threw and the compressed air comes from the top of the Tee. Like this.
I was thinking it might be better to have the smoke machine come in the top/middle of the tee and the air blow it threw the Tee. I'm not an engineer so I don't have a clue but my thinking is if you have the compressed air coming in the middle of the Tee it will want to travel to both ends of the Tee equally and fight against the smoke machine's blower. Just seems like if the smoke was introduced in the middle/top of the Tee it would mix with the smoke better. Like this.
Any thoughts on which way might be better to have the Tee and where to have the smoke and air to come into the Tee?
I'm thinking I'm going to put all the parts in a small plastic toolbox just to keep everything together and protected instead of just laying on the shelf. Figure I will have some fittings and hoses, and block off plates and will be nice to keep everything together and neat. If I just put it on the shelf the plumbing or regulator will get damaged some how. I haven't decided if I'm going to "mount" everything in the toolbox so I just hook up the air and output hose or if I will just lay it loose. Kind of like the idea of cutting holes in the top toolbox tray and mounting things so that the air quick connect is facing up and the output hose would have a barbed fitting facing up and the switch be in the tray. So I just open the lid and hook up two hoses and press the button. We'll see what comes about.
Any thoughts or advice so far? I have to pick up some 1/4" pipe ******* to plumb everything together. Hopefully will get some time to get to the store to pick up a few more items this week to make some progress on this and some other projects I have going on.
