alan camby
1. Had a electrician many years ago tell me that a receptacal cannot be used as a terminal strip. Meaning that a regular receptacal cannot have the black line wire on one brass colored screw and a load black wire on the other brass screw. I have seen many homes wired to daisy chain from one outlet to the next. I have been running the two romex cables into the receptical box and using a red wire nut to tie the 2 blacks with a 3rd short piece of black wire to feed to the receptacal. The white wire gets the same treatment.
What about the spec grade receptacles with the wiring holes on the back and the screws that pulls a bar to clamp the wire. Total of 4 holes for the black and four for the white. Can i put the two blacks in two close holes on the hot (brass colored) side and have the one screw tie them? Same with neutral side (silver colored). Can I choose one of the 2 holes that are clamped by one screw? This way I would not have to go thru the wire nut procedure.
If this cannot be done, Why are there 4 wire holes on both hot and neutral?
2. Are you guys putting GFCI receptacles in pole barns? If so, Is it code? What about 220vac outlets for welders that use plugs? What about 220 with disconnects and conduit ran to the load like a large compressor?
3. Where are arc fault breakers required to meet code?
4. See many homes with 20 amp breakers (with proper 12 gauge wire) and 15amp rated receptacls and switches. Does this meet code? For the extra $.50 i would use the 20 amp stuff, but is 15amp ok?
Thanks
Thanks
