Ok here's the deal I bought this house about a year ago it had a new whirlpool 50 gallon electric water heater installed the month I bought it. I haave used this unit for a little over a year with no problems well last Sunday the water went cold I have recently discovered this is a 240v unit hooked to 110v. There are currently no more spots in my breaker box to put a double pull breaker in. I have ohm checked the two heating elements both of them shows 12.4 ohms. There shows to be power to the unit. I ohm tested the wires going into the unit and visually inspected. One was questionable so I replaced it and had hot water for a few days. Now I have no hot water again. Whoever installed it put the red wire to white and blackto black and ground to ground screw on unit. When iI put my volt meter on either pole above the reset switch and the ground wire it shows like 124 volts but thermostats won't click on or off to power the elements. I know it needs 220v power to work to its full. Potential but its not in the budget for a few more months to hire a professional to upgrade my service and it worked fine for a year. Can anyone offer any suggestions?
