Wire Stripper Tools
Loscaldazar
I have a chinese wire stripper tool and don't really like how thin the steel is (flexes when trying to strip, crimp, etc). It looks very similar to the channellock 908 (except the top and bottom functions are switched, linked below).
I would like something made in the USA, Germany, Japan, etc (not china/taiwan).
I am looking at the channellock 959 (http://www.amazon.com/dp/B0002FT6EY/?tag=atomicindus08-20)
and channellock 908 (http://www.homedepot.com/p/Channellock-8-1-4-in-Wiring-Tool-908/202247298#.UmMuYSR5czU)
Anyone have any insight on which one to get? I'm leaning towards the 908 because they are similar to the pair I have now in terms of options and what I have used in the past.
Any other brands to look at?
SchillerM
Portland, OR
I use what looks like the 908 at work, those and a set of Kleins are the two strippers I will hunt down when I need them. The others we have (dozen or so cheapies) do not compare. No flexing issues or bad strips with them so far.
Matt
Elvenhome21
Sheboygan WI
all depends on what application your using it for most. I work in the sign service industry and all the guys use the 908 style. Biggest issue with the 908 style is striping the outside sheathing off of small wires and not nicking the inside wires insulation. Then I prefer the 959 style. Also If your doing any crimp connector you need the 959 style.
jeremy v
I don't know how much crimping you do in comparison to stripping wires and using wire nuts, but if you do more wire nuts definitely get the 908s if those are your only two options. There are many times when you need to strip wires in tighter areas working on cars and when doing home wiring, and having to get the wire end all the way to the handle located wire stripper on the 959s can sometimes be a real hassle.
That being said I would not buy either of those 2 strippers for my own use. The 908s are the better plier of the two, but they have less versatile crimping dies and they add crimping dies for cable tv coax cables (rg6 or equiv.) which most people will never need or use, especially since most coax terminations are done with compression type connectors now anyways, not crimped connectors. Stride tools/Imperial make some really nice versatile good quality crimpers that are not the best at anything, but they are very good at everything. They used to be the crimpers that Channellock re-branded as their own before they changed over to their current style strippers several years ago. I used the older Channellock (Stride re-brands) commercially and personally and they are very nice for what they are. They are currently sold under the Stride name (IE-110) but are hard to find. They are re-branded, more easily found, and cheaper under the Craftsman(82563), Crescent(WS19H), Matco(MST46E), and several other brand names. They are made in the USA. I also have the newer Craftsman re-branded version and they are every bit the same as the older Channellock version in quality. I don't think Sears carries that Craftsman model anymore, but they can be found on Ebay sometimes. If price is a concern for you, keep an eye out for one of the re-brands on Ebay for a few weeks and you should find something, or look for some used wire strippers that visually look exactly the same and are made in the USA and they will most likely be the right ones. I purchased my Craftsman branded version stripper/crimpers about a year ago NEW for $8 including shipping with very little effort on Ebay.
The Stride version crimpers/strippers have better crimp dies then the modern Channellock 908 versions by a large margin in my opinion. Compare the die shapes visually (the Channellock are all the same shape and only the size of the hole in the middle changes), the strippers are located at the tips, the tips are more narrow to fit in tighter areas, and they just work well. The only caution I would give is that unlike higher end wire strippers, these strippers only list one set of gauge numbers for the corresponding wire stripping dies. The numbers given work for stranded wire, but if you are stripping solid you need to shift over one die for the same wire gauge for it to strip cleanly. Better strippers have two columns of numbers, one for stranded wire and one for solid, but all the second set of numbers really does is shift the wire over one spot for solid.
As far as I know Stride/Imperial is the company that also makes Klein strippers, because they look and perform exactly the same in every way. I have used Klein strippers and crimpers heavily and I have not noticed any difference in quality between them and any of the other pliers that Stride makes regardless of what they are re-branded as. It all just comes down to the features they each offer and how specialized of a wire stripper they are.
The ones shown in my picture below are the model version I use and think highly of. They are excellent for general use in the automotive or homeowner field, light to moderate commercial work, or to put in a car toolbox as a do everything electrical tool for general roadside repairs.
theoldwizard1
SE MI
Ideal 45-778 Good crimper and bolt cutter average wire stripper.
View media item 34367
Ideal T5 strppers Better strippers
pokey459
neonnblack
Reno, NV
I love my 908's, I seldom use it, not alot of electrical work for me. but when i do use them its so freakin fantastic, especially going from the cheap chinese ones.
kwhitelaw
not sure the COO, but I've always used the craftsman professional brand. both sizes, the super small gauge and the standard gauge size..
kwhitelaw
nicksnothereman
In the Mojave
I think channellock makes decent stuff but not sure where they're made. I don't really do a lot of electrical so I typically just use a mini razor scraper for inline splices or to strip ends of electrical wire works well for me. If I were to buy a real stripper I'd probably go greenlee something like the g-1955, I think I've seen them in lowe's they look well made to me and "spring" loaded (one of those collapsing metal deals). Those might be chinese though. Of course they aren't full featured but you should go in store and take a look before you pay solid money for anything.
nicksnothereman
In the Mojave
jeremy v
zkling
$ = Craftsman 982563 - Good quality, Basic, low price $10, non spring loaded, multi use.
$$ = Ideal T series - Spring loaded, if you like that feature
$$$ = Ideal strip master - Automatic, works really slick. Not the best in all applications though IMHO.
zkling, has been schooled in wire strippers over the past few months, thanks to members here. :beer:
scaron
ypsilanti, michigan
go for ideal or klein (or, sure, knipex), and think outside of the box of the standard 'six in one' tool; look at some of the more sophisticated tools in their product lines, you will thank yourself and it doesn't cost _that_ much more than the channellocks (that said, i do always keep a good six-in-one around, too). i find you generally appreciate a spring loaded tool more when you have a lot of wires to do.
CWP1616L
USA
The second link posted by CWP1616L for the Williams brand strippers/crimpers are just one more re-brand of the same Stride/Imperial, Craftsman, Matco, Crescent, etc. strippers that I mentioned in my previous post, so they are good.
They're both made by Stride-Imperial.
zkling
http://www.amazon.com/dp/B000OQ21CA/?tag=atomicindus08-20
Using a wire stripper and cable's such a tool. Very convenient to strip a variety of cables, flat and round, the inner and outer shell. Strips cables of different sections and can crimp lugs. Make it different firms. Use in the production work for a long time.
Does that nick the wire at all? What I don't like about it is that it only cuts the top and bottom of the insulation and then rests on the wire inside to act as a depth stop. At least on the ideal strip master it has specific dies for different wire sizes that cut all the way around the insulation and then have a built in stop, not relying on the soft copper wire to limit depth of cut. :dunno:
Ign
Butte Peak ND
Agreed I use the top version if space is not an issue but for things like under a dash, etc you gotta use the bottom version because it takes up considerably less room, not only in size but in placing the wire "above" the pivot (like pliers) vs "below" the pivot which takes a ton of room in tight quarters. I use Kleins for the bottom version, got 'em at HD
Vvmvbb
CT
That style works really well. I've been using the Kronus version of it lately and it doesn't ever nick the wire or pull strands loose in my hands.
Here's a review
I also still use the fine gauge T-stripper, especially for 30 gauge wire.
Klod
Россия, город Го&#1083
zkling At its work tried many tools for stripping of cables and wires. Some broke down with heavy use, and other poorly cleaned out the wire insulation, or it is inconvenient to use. Stopped on this model, a 6-years old everyday work is not broken and is comfortable enough to use. I had to smooth out of 0.35 mm. to 6 mm. square.
I beg Sorry for my bad English, I write and read through a translator.
bimmerTEK
texas
Irwin Industrial Tools 2078300 a ++++ for a technician. I have the radio shack version and is great so far.
richfinn
Leeds, Yorkshire, England
I have 3 types
Snap on pw type
Trident auto strippers (generic rebranded)
Teng adjustable end strippers (useful where space is limited and wire is too short to manoeuvre)
I also have a notched blade on my pocket knife if I get stuck without tools somewhere.
L
Loscaldazar
Jeremy V
The type of crimping dies I am used to are the type on the 908 channellocks (same shape, just different sizes holes) that crimp from both sides. With the pair you linked, it appears that it just crimps from one side? Is that really better?
jeremy v
Jeremy V
I have done manual pull testing with both style crimps and the crimp holds stronger with the crimpers that dimple one side heavily (as long as you dimple the side opposite the barrel seam) instead of evenly dimpling two sides. I don't know why it is, but those are the results I get. The best thing for you to do is to not just trust me, but to try a few crimps of each type and do some quick pull testing of your own. There are many brands of crimps with different barrel thicknesses etc. so there might be some that crimp better in other ways. Some people might have arthritis as well and they are not able to crimp very hard without pain, so for them a set of ratcheting crimpers might be best. Ratcheting crimpers can be amazing, but they can also be very picky as to the brand and style of crimp terminal used. There are lots of factors, so not everyone is going to like and get the best results with the exact same pair of crimpers.
Ideally everyone should really just try a few crimpers and see what works best for their specific situation, but if you can't do that the next best option is to buy a set of crimpers that has the most variability and versatility possible by having multiple die styles dies, etc. One issue I have had with the 908 style dies on occasion is that when crimping insulated terminals the dies smash and spread the terminal insulation almost into two separate rings because the crimp pressure goes almost all the way around the terminal. The squishing pressure spreads and smashes it and it looks rather amateurish when finished. The dimple type press hard in one spot on the insulation jacket and that spot is on the bottom and out of sight when everything is finished, so it all looks very clean, presentable, and the insulation over the barrel is rarely if ever deformed much or damaged.
If you prefer the standard style crimp that presses in on both sides, the crimpers I linked to still do have a set of those dies as well. Having differently shaped dies just allows you to do more types of crimps well with limited tools. You can use the dimpled dies to work a standard bare automotive style crimp that has a cross-section that looks like a capital B (with a little extra effort on your part) and it will hold very tightly, but there is no way I know of to do a B shaped crimp well with the dies on a pair of channellock 908s.
Last but not least, in life there will always be times when situations are not ideal. You might be stuck on the side of the road and need to temporarily crimp an 18 gauge wire with a terminal crimp designed for 14-16 awg only. I have always been able to get the single sided dimple crimper dies to work and still get me an acceptable temporary crimp the first try, and I can't say that about the double sided die style. I no longer own any crimpers that crimp like the Channellock 908s, because in my opinion they just fall short in the versatility department, and there were no situations that I could find where they made a stronger crimp than another more versatile option already did.
jeffmoss26
Cleveland, Ohio
Klein 11055 and 11046 are my go-to wire strippers. I use separate crimpers...either Klein 1005 or Channellock 909, depending which tools are with me.
amlv20
CEN-CAL
http://buy1.snapon.com/catalog/item...roup_ID=742282&store=snapon-store&dir=catalog
these are pretty awesome. they are compact yet provide impressive leverage for crimping. the forged construction vs stamped makes them quite robust
YES!! This one! I bought it because how people raved about it on here, and it's the shiznits! It's compact but yet still an amazing crimper, the strippers are clean easy and sharp.the cutter is amazing it just slices bare wire easy and very clean with no mangled mess, and it's located on the inside of the jaw not on the tip of the jaw.which is awesome because trying to crimp in tight spaces doesn't result in accidentally cutting other wires in the harness.
gagreen
Colorado
Second the snap on strippers for plier style stripping. I use a set of the automatics most the time but the snappy's are god sends when you need them.
And I do more than a little wiring... lol looks like a channellock add
