It's an older click type...I believe the model number is 44595.
How do you know a new one is calibrated?![]()
Find a someone with a beam torque wrench and use a 8 point socket between both torque wrenches and check you clicker against the beam. Check multiple ranges and make the call from there.
As already mentioned, it is just cheaper to buy a new torque wrench than to have a Craftsman sent off for calibration check. Most calibration shops will just check it for about $50, then any adjustments will cost more on top of that to dial in the calibration.
can you elaborate?
just couple them against each other?
