Use a weatherproof horizontal outlet cover in a vertical placement?
R
Ryland
Rhode Island
Thats what I figured. I have vertically mounted inset boxes that arent playing well with vertical covers (there is barely enough room to get fingers in to access the outlets on the vertical covers I have found.
pattenp
Virginia - USA
How about this cover?
ibcGetAttachment.jsp
R
Ryland
Rhode Island
I wouldnt be able to get my fingers under the bottom edge since it is inset in the wall. The box I have to install it into is 3"x5" and is inset about 1/2". The only one I found is this one
but I havent found it instore or online.
Gary S
Bismarck, ND
I wonder if I can grab one locally since I dont have a Menards in RI.
That *****. Life is tough when you have to live without a Menards. Lowes and Home Depot don't make even a good second best.
Your local electrical supply shops would also have what you need.
pattenp
Virginia - USA
You may have to settle on using the horizontal one. Why is the outlet box recessed? Can you post a picture of what you're dealing with?
R
Ryland
Rhode Island
I wonder if the horizontal style would be ok because nothing can run down onto the cover from above due to its being inset. I probably shouldnt chance it though.
where2
South FL
Take the cover in post #5, drill two small holes in the lower corners using your smallest drill bit, add a piece of monofilament fishing line to lift the lid, and seal the holes with a dab of clear silicone.
Although not a UL approved modification, it seems much less likely to leak than the other options involving a horizontal mount used vertically.
R
Ryland
Rhode Island
Or add a white screw/handle to it. Not a bad idea at all, thanks.
MTW
SE Michigan
Use a "bubble cover" "1-Gang Non-Metallic Weatherproof In-Use Cover"
Install it over the inset box
Caulk it around the top and sides to the siding or trim ring opening.
leave the bottom un-caulked for drainage if it ever does leak.
Bell 1-Gang Non-Metallic Weatherproof In-Use Cover - Clear-MM410C-8 at The Home _2013-10-28_02-2.jpg
This will protect the outlet while using it in the rain, not just when it's closed. It's approved for horizontal or vertical use.
These are also available in die cast for rougher use situations.
http://www.homedepot.com/p/Bell-1-Gang-Non-Metallic-Weatherproof-In-Use-Cover-Clear-MM410C-8/100173013#.Um4DqBC8zfo
R
Ryland
Rhode Island
I ended up using a box similar to what was previously mentioned which sticks out from the wall. My wife doesnt like it but I will hide it under her potting table.
