I have an old 10 amp Sears battery charger and for a few years now the surface mounted square amp gauge has had its crappy clear plastic cover missing. Popped the case top off and behind the square guage is a 2 inch round hole through the metal face of the charger. I'm thinking...why not just stick in a basic 2-inch round automotive amp gauge?
To you ohms guys...any reason that wouldn't work? An auto gauge reads both + and - and (as I recall) most don't actually read the number of amps.
This original meter only reads amps + from 0 to 20, which to a wrench head sounds odd because its only a 10 amp charger. I assume a 10 amp charger will max out at 10 amps output...no?
Anyway I'm sure somewhere in a box I have an old 2 inch round automotive amp gauge. Is it worth me digging? Will it work. ..keeping in mind all I need is to see if the battery is pulling a charge and once charged...assume it should be in the center null point or at least close to it?
Gordon S.
Gordon S.
