Petroleum jelly lubricant
lpoolck
I have bought one of the 36" homak tool chest from Costco and it suggests in the manual to lube the ball bearing runners with a high quality petroleum based lubricant with a jelly consistency.
I have tried to find such a lubricant but I am struggling to find one - could anyone point me in the right direction?
Also I have tried other lubricants and I prefer the original lubricant that came with the chest.
I have tried to contact homak but they can't provide any information on a supplier/brand.
The Ratchet Man
Georgia
Does Vasoline not meet the criteria you posted?
If it's quality enough for....well...um...then it should be quality enough for your drawer slides, correct?
zakmartin
Seattle, WA
After a while, Vasoline starts to get drippy. I'd stick with a tube of HP grease from the auto parts store.
L
lpoolck
Wffew ! - From the title I was expecting a whole 'nother conversation. :scared:
Haha. Exactly what I was thinking. I am from the UK so not sure if it being USA made if the reference/name was the same on the other side of the pond. Turns out it definitely is.
L
lpoolck
I've tired Vasoline but it was no good. As previousky stated it runs. Silicone spray is ok but the drawers are too noisy when using it.
L
lpoolck
I find it hilarious that you "prefer" a specific lubrication for your drawer slides.
I find it hilarious that you have taken the time to post something that makes you come across as an absolute ******.
jjjrmx5
Cincinnati, OH
LOLOLOLZZZZZ!!!!
Reminds me of the joke where someone used "Astro Glide" instead of brake fluid when doing a brake service and now their vehicle wants to "rear end" all the other cars.
:lol:
LOLZ.
As for slide lube, a search is necessary.
Bearing grease attrats grime, White lith breaks down over time and dries out.
I like engine assembly lube or the red lube of love, but it depends upon your temps.
Factory was likely a light bearing grease or lube.
Work in a machine shop or body shop with metal shavings or lots of filler or paint dust and you need to then factor that in too.
I've seen it all.
L
lpoolck
Back to the topic at hand I use Boeshield very sparingly on slides and door tracks it works well!
Never heard of that before. Just read up on it and it sounds like it would be a good for my bike!
What's on now is a slightly tacky clear lubricant. Almost gel like in consistency.
AMC31B
SE CT
Superlube is almost the exact consistency and texture as vaseline. I would goop it up with superlube and call it a day. You can get it cheap at harbor freight, amazon or online.
L
lpoolck
Sounds like it's superlube that my tool chest came with then. I am from England and it's around $30-35 for 85g over here!! Appears that it's not sold directly over here and it's only stocked by a few retailers who are obviously selling it at a nice premium.
e_d
Oregon
The first thing I thought of was lubricating radiator hoses so they go on easier, I guess I don't have the dirty mind I've been accused of.
nickleone
To the OP,
The instruction loose something when they are translated from Chineese.
I had a chemical product with instructions to mix the two chemicals for "EXACTLY 5 to7 min" LOL
The instructions most likely mean NON LIQUID lube. Try common white grease.
Nick
L
lpoolck
To the OP,
Nick
Haha. So did you mix the products for 6 minutes then?
You may be correct but when I emailed them they also referred back to the 'petroleum based lubricant'... Guess their email team are also from the east.
L
lpoolck
So they are recommending a product they have no idea what is? :headscrat
Big head scratch. I asked for one to recommend or name and they just signposted me to a local hardware store. Bit disappointed with their response to be honest.
Steinmetz
Washington State
Lubriplate.
skruft
There is Superlube, some synthetic greases that seem similar that are used on bicycles, and also a silicone grease called Sil-something that is the same consistency.
The only mechanical item I know that is generally lubed with Vaseline is the snap-on fasteners on boat canvas, as they get dry and hard to unfasten when left in the weather.
beatcad
NOVA
i use the white lithium grease. not the spray but the thick stuff in the tub. a remove the drawers and brush it on each slide and drawer.
depending how dirty your garage is you may have to do it once a year. i do it maybe every other year.
the tub may be 5 or 6 bucks but it'll last forever and the uses are endless.
creaky car door or hood hinges, pressing a bearing....
