vga
Re: what did you do in your garage today?
I installed f/r brakes onto my 91 BMW 318.
rharman
SoCal
put a front end on my '55 Harley so I can finally roll it around.
Haven't seen a '55 Shovelhead in a long time :lol_hitti
beatcad
NOVA
ok ya got me there. the bottom end is '55 and left the factory as a panhead.
heck the bottom end may(is) be the only thing from '55. putting a shovel top was the hot lick back in the 70s.
my title says '55 so as far as the DMV knows it is:beer:
spotco2
NW Georgia
Nice!!! I hope that being in Georgia, that you won't need it on a daily basis though. They can spin a power meter. By buddy put one in his garage, and he was out there almost every day for a month until he got his power bill. Later on this winter, if you would, come back an let others know what it runs you. I know that Georgia will be different than the **** weather we have in Ohio though. I run propane on a 120 gallon tank, never let the garage get below 50f and when I'm out there I kick it up to 70f. The tank of propane last me maybe 1 1/2 months. So I'd be curious how electric compares. BTW....my heater is a 45,000btu Hamilton.
Ooh! Ooh! I started installing mine last night. Is yours 5K or 7.5K? I got the 7.5K to push back the New York winter.
Mine is the 7.5K in a 30x30 with open trusses and 10' walls.
I was hoping to just knock off the chill. Since it was supposed to get below 30° last night, I left it on low from about 9 last night until about 9 this morning when I went out to move some things. It was not cold, but was not warm either. I checked the meter last night when I walked out and again when I walked in this morning. It cost me 11 kwhr. I don't think my 10 sets of T8's used that much the first month I had them turned on.
I might have to put in a ceiling of some sort even though I didn't really want to. I also had to put a box fan over in that corner on a ladder to help move the warm air around. I could tell a noticeable difference from one side of the building to the other. Maybe some ceiling fans would help? It would be cheaper than a ceiling.
JasonJ
Las Vegas
I had some Multi-Color LED lights that I was trying to use as task lightning but it just wasn't bright enough so I ended up with something else but I still had a strip of these multi-color LEDs. I thought it would make a good Under counter top light to add light to the drawers in the work bench.
With White LEDS on:
With Red LEDS on:
The movie of Disco Workbench:
TheClaw
Chicagoland
Changed the oil in the Benz ('67) and noticed some seepage from the left side of the head gasket.
Uh, oh.
BJ42LX
WNY
Mine is also a 7.5K in a 22x30. I have a small propane bullet heater that works well, but pushes a bunch of moisture into the air resulting in a lot of condensation. It's also a bit of a pain to manage the temp by turning it on and off.
I only heat the garage when I'm out there doing something. I plan use both units to take the chill off and leave the electric to maintain it. The electric should be perfect for that.
My garage is attached with insulated walls and drywall ceiling. At some point I'm going to insulate the ceiling/attic, which will cost about $400.
11kwhr is a lot of power. My Chevy Volt takes 16.5kwhr for a full 38 mile charge. That's a lot of energy.
sgs
After 3 years of tripping over the old washing machine front panel I saved...finally turned it into that shop whiteboard.
Gordon S.
sgs
Why the picture is sideways. ..I have no idea?
Gordon S.
383 240z
Findley Twp. Allegheny Co.
I moved my compressor and scrubbed under it. Put a drain in the compressor to make oil changes easier. Started building the framing for the wall behind it. Also started a shelving system above my main workbench. Stopping by the Home Depot to get the rest of my needed supplies. Keith
RivennHewn
PNW
Finished up another work table for the shop.
Reclaimed lumber, reclaimed table base from a paper ream cutter with 14 gauge legs and shelf.
Added some free casters to it.
I'm into this one for about $9 in paint.
kmkalf
Buffalo, NY
cut top off the parts truck and pillars.
roger53931
Hi gang, New here. Just finished the outside of the new building. 32x40x12. Just started the wiring. Have found a lot of ideas from the site.
Slednut
Washington state
Primed some siding for my new addition. It's the only stuff I could find that matches the rest of the house. The manufacture says prime it or no warranty. Was able to do 30 Saturday and 30 today. Need about 50 more. They are 12 inches high and 16 feet long.
gipraw
Cypress, TX
Took the next step in upgrading my workbench situation by finishing the install of the two side boxes and started on the frame for the two big boxes.
p_mori7
Montreal, QC., Canada
Installed 2 big-azz posts and an even bigger beam to reinforce the header over my pop-out...pics are in my build thread...link in my sig below.
skulldrinker
Bolingbrook, IL
Cleaned up an oil spill. I'm not storing used motor oil in plastic milk gallons anymore. It just cracked sitting there on the floor. good thing it was only half full. or have empty.
gipraw
Cypress, TX
I use Home Depot 5 gal buckets for that very reason.
Buford T. Justice
Montague County
Jason, I love that! Nicely done.
56vette461
For this:
I have the same heater. It was too costly to try and heat the whole garage so I started using a heavy clear construction plastic on a 3/4 in conduit rod assembly to surround my work area. I direct the heat into the work space and it makes it very comfortable on cold mornings. As a disclaimer, living in Northern California is not really having cold weather but its cold enough for me.:D
Grayguy
Worked on my brothers garage
Sent from my SAMSUNG-SGH-I537 using Tapatalk
PCO6
Newmarket, Ontario
I don't think "moving" your garage qualifies as working "in" your garage. :lol: That looks like a big job. Do you have a thread on it ... or can you start one? It looks fascinating. :thumbup:
zmotorsports
Northern Utah
Performed a major service on our coach over the weekend before putting it away for a couple of months. This way she will be ready to roll after the first of the year for the new RV season.
Changed oil, filters, serviced the oil bath hubs on the steer and tag axles, changed the desiccant filter/dryer cartridge and repaired a shock mount that I noticed was in need of some attention.
Mike.
IONH
Central Massachusetts
I use anti-freeze, windshield wash and laundry / fabric softener bottles when I run out of empty oil bottles.
I made a trellis out of 1/2" PVC pipe and connectors.
That's a neat idea. I'll have to remember that for the spring.
transplant_wi
Madison, WI
Replaced a lower ball joint on my aging Honda Civic. Autozone has a free tool loaner program where I got the ball joint press and the Honda adaptors - you leave a deposit, which is refunded in full upon return of the tool(s) within 30 days.
ADSR
I moved houses for 6 years. It's a lot of work, but the payoff is great.
I believe any house is mobile:lol_hitti
