G'day all,
Ok, looking for input... Snow hit today - phone calls to come save friends from ditches started...
Want to setup the truck with a winch again - no I don't want bumper mounts / typical hitch mounts. Want it to be removable - because, don't need it in the truck 97% of the year - and it's my work truck, It'll need to come out to accommodate earning a living semi-regularly.
[/URL]
That'll be the base of the unit... Specifically the base - (the big H shaped steel bit the 5th wheel drops onto) Planning to mount my EPI9000 winch on a 6" channel above that cross bar.
But - need to fabricate something between a Gin Pole and Holmes wrecker - to get the winch line off my tailgate (also gives me lift on recoveries). And this - is where I need help...
Want it to mount fully to the 5th wheel hitch, fixed elevation to clear the tailgate, and removable (ie pull 4 pins and stash the booms under the tool box). Trucks got a 6'6" bed - so only really need 4-5' of boom to get past the tailgate. But - I do want to be sure it's not going to fail in use... I was eyeballing a pair of 2x4x.125 wall HSS tubes I have here... But not sure those will be adequate?
Also debating whether it's best to mount the booms high - with a brace down - or mount the booms low and have the brace going above...
Anyone have some thoughts / words of wisdom (other than call a tow-truck, yes we know these friends... Yes these friends are cheap like me and know I used to drive one...)
