OSB vs. ply roof
ADSR
In regards to the strength of OSB. OSB has been shown to be of an equal strength to plywood as a structural panel. This has been stated by the American Plywood Association. So, what is the reason that these engineers are not allowing it?
What they said to me is, with the new seismic codes coming in, it's no longer code compliant for the roof. The walls are still fine. Also, they could be installation issues as well. Most people don't know there is an aarow showing the direction of strength on the sheet for install.
ADSR
Here is a paper by the Engineered Wood Products Association explaining the weaknesses of OSB - typically as a result of installation problems. The fact is that OSB is typically less forgiving of careless installation than plywood - and careless installation is, unfortunately, not all that uncommon.
http://www.ewpa.com/Archive/2006/aug/Paper_266.pdf
Holy ****! Did you see the shear reduction for over driven fasteners??? All the coil guns i've ever used always over drive by at least 1/8 inch! When the compressor is full, a 1/4 is the norm. And that's at 120 PSI.
spotco2
NW Georgia
If you buy OSB at a big box store look and see how many sheets have the impressions of large bolts/nuts pressed into them! Saw tons at HD that looked like someone tossed a handful of hardware on them and then ran them through rollers.
LOL...I noticed that the other day on some HD OSB. I couldn't figure out what those funky donut looking things were on all of the sheets. It looked polka dotted.
KCarGuy
50 miles outside Chicago, illinois
Putting Strength and Cost aside...I Personally use Plywood on everything during my own Builds or repairs.
I dont like OSB, never did.
It Breaks easier than Plywood.
I can rip it off of a Roof and leave the nails behind with a good tug.
I look at OSB, like i look at Particle Board Furniture....Ugh!
I understand to widespread use of it...Lower cost for Contractors and Manufacturers looking to get every ounce of wood out of a Tree...even the Shavings.
But...For Me...On my own House or Garage, Or even a Shed...Its Plywood all the way.
KenC
oklahoma
That's only if your nailer doesn't have a depth of drive setting. Most of mine do, those that don't have had the drive pin ground off to reduce the depth.
NUTTSGT
Northern Central Ohio
There are studies to prove each side, you just have to look for each one. Honestly, I really don't care what people use as this could be the next biggest debate compared to airlines and wall coverings.. . . . tastes great, less filling. :beer:
http://www.rci-online.org/interface/2003-06-haughton-murphy.pdf
This conclusion should not be construed as a blanket condemnation of the use of OSB structural sheathing in roof, wall, or
floor assemblies, even in the wettest and most humid climates.
OSB is a well-engineered product that provides significant economic, structural, and environmental (through the use of lower
quality and more easily farmed trees) benefits. For many uses,
OSB provides performance and/or service values that are superior
to plywood; however, for other uses the opposite may be true, particularly during extended conditions of excessive moisture.
Industry groups correctly note that, “When properly installed,
neither OSB nor plywood should be exposed to those extreme conditions...”; however, they are incorrect when they conclude this
assertion by stating, “...and both have performed equally well.
