tool / pliers for p trap
PoorOwner
CA
What is the right tool to undo those big abs traps
I heard always referred to channel locks but I have a 9.5 " one the jaw is not big enough..
Would a 12" one work?
I know they are supposed to be hand tightened but I have trouble loosening them sometimes..
CWP1616L
USA
You mean these slip joint nuts?
They make a wrench for those:
Download this catalog:
http://www.superiortool.com/2013catalog.pdf
sberry
Brethren, Michigan
A real plumber does not own either of those,,, a 9 inch plier or that sissy wrench. Get a pair of 12 inch Channelocks, if you don't have a set you need them.
sberry
Brethren, Michigan
They carry a 440 in their back pocket. They are a super unique tool in the same way a pair of number 9 Klein is
Jamming
I've usually just used my hands, the ones in my house and my in-laws and my neighbors etc..haven't been that tight. I think once I've gotten out my BFPC(big freaking pair of channel locks).
BTW..I'm not a big guy nor am I freakishly strong.
sberry
Brethren, Michigan
I got to have a pair within 25 ft of my body at all times or I have an anxiety attack. A pair of crappy 9's have saved many a day but they are easier to find, the good ones are always gone.
P
PoorOwner
CA
Is this a good investment as far as getting the biggest plier in my tool box?
http://www.homedepot.com/p/Irwin-Vise-Grip-12-in-Quick-Adjusting-Groovelock-Pliers-2078112/100488494
How about 16 inch (copy paste link)
http://www.lowes.com/ProductDisplay?productId=1115141
Reviews for 16 inch
This was the PERFECT tool for removing and reinstalling the P trap under our bathroom sink. Rescued my wedding ring. It was big enough to fit around the 3" nut/collar while giving good torque, but light enough to grip with one arm and not fall down or off in a tight spot. VERY SATISFIED!!!
If you need a very large pair of slip-joint pliers, these are big, they are Channel-Lock brand and they are made in the United States of America.
Win??
P
PoorOwner
CA
I also need a auger from the big box store :( beyond the p trap of the kitchen sink..
Something about cold weather, grease and potatoe peel
any recommendations? Hand or drill type?
Gmonkee
Another vote for oil filter pliers, with a light touch they won't muck up the fittings either.
I also have cheap 10" channel-lock type pliers with the handes cut back to 7", gives me a wider pliers on a short handle for the smaller spaces long won't fit. I'm very tempted to do that to an oil filter pliers now.
Usually once the trap parts start move a hand can finish the job. Plumbing isn't about torque values. Just make it seal.
zkling
If it is plastic I usually use a strap wrench of some flavor either rubber or cloth.
P
PoorOwner
CA
Just got the 16.5 channel lock made in USA
Did the job although might be a bit big
zkling
I doubt you will live that long... :lol_hitti
ps: did you know that color blue is a registered TM as "Channellock Blue"?
I thought cornwell and a few others rebranded the Channellock line with colors like orange? :dunno: Where is Jeff, he'll straighten this out.
Heavy tech
If you're in a jam, use your belt! A leather belt has saved me more than once. Was the easiest thing to use to get the oil filter off my old Cavalier
Sent from my iPhone using Tapatalk - now Free
SlappyWhite
Upper Canada
Not the "right" tool but I use a strap wrench. One of those ones with the rubber strap. I find more times than not I do not have enough room to use channel locks.
Pumpman1968
Upstate, NY
Geez........if your worried about the color of the handles on your pliers why not just get out your nail polish and put a fresh coat on them..........Magenta may even match your Timberland "workboots"
P
PoorOwner
CA
Dirty job today at Least I gotta new tool
I think will work on some oil filter too
zkling
Maybe I will thank you very much. I'm more of a periwinkle purple man myself though. Magenta is just a bit too loud for me. :p
