What Does This Do?
jims09build
All you electric motor experts should know what this does on this old Century 2 HP motor. (First Picture) I don't have a clue.:headscrat I've had it on my Ingersoll-Rand Type 30 compressor for over 40 years and it has run faithfully all this time. I just restored the compressor and cleaned up the motor and painted it which brought up this question. I have never changed the setting from where it is now. I added a couple pics of my setup.
Thanks,
Jim
drcliff
That's an adjustment for the motor's starting circuit. Before cap-start motors, some motors had basically an extra set of brushes that only worked when the motor was starting up. This (sort of) doubled the starting torque. It's set at the factory and then never again, I think. On your motor you can swing the start brushes far enough to make the motor start & run in either direction.
J
jims09build
Thanks for the reply. I've always enjoyed watching those extra brushes kick in and love the sound it makes. Do you think mine is adjusted to maximum torque?
Since I put new rings in the compressor it seems to struggle a little sometimes when starting.
Thanks,
Jim
scw1991
Actually, this changes the motor shaft rotation on a repulsion induction motor . By loosening the bolt, you can rotate the brush assembly to either position "R" or "L". In today's terms it's either CW (clockwise) or CWW (counterclockwise)
J
jims09build
Thanks for the explaination.
signcrafter
That is really nice! What are those 3 beautiful pressure gauges for on the wall? I see one comes off the air lines but the other two are at different pressures?
If the rest of the shop looks like that I think we are going to need a full shop tour picture thread!
J
jims09build
Can any of you AIR experts figure how much cfm this unit is capable of with this information?
Motor is 2hp
RPM is 1165
Motor sheave 6" dia
Compressor sheave is 18" dia
1st stage bore is 4"
2ND stage bore is 1-1/2"
Stroke is 3-1/2"
Inlet size is 1-1/4"
Outlet size is 3/8" pipe size
I'm running it set @100# on to 125# off. Takes 3 minutes to do this.
Thanks,
Jim
J
jims09build
The 3 gauges are old Ashcroft gauges that came out of an old nat. gas compressor station about 40 years ago. The last test is written inside dated 1961. The faces screw off and they are solid brass. I've had them stored for 40 years. 1 is for tank pressure, 1 is for regulated pressure and the 3rd is the pressure going to my other garage about 80 feet away. I have a leak somewhere in the line going to the other garage and had the valve shut off so thats why the pressure difference.
I would be happy to show the rest of the place once I get it cleaned up. It's a pretty nice place to keep my 65 Shelby Cobra Replica I built and painted using this same compressor.
Jim in Pa 23 degrees this morning, brrrrr
Jim
Jtcrep
Motor is 2hp
RPM is 1165
Motor sheave 6" dia
Stroke is 3-1/2"
Thanks,
Jim
You need to know your tank size. I used CFM Calculator from the google play store on my android phone. For a reference my T30 model 253 made 17.71 cfm when starting at zero and going to 125psi in 7minutes 42 seconds. I haven't calculated the cfm in a working environment yet.
J
jims09build
Tank is 80 gallon.
Thanks,
Jim
