I may go pick this up tomorrow. What's it worth?
How many speeds? Does it have an intermediate pulley? I see what could be a table elevation feature?
Table elevation was standard on that model (and absolutely necessary with that production table).
You could say that again.
First time I pulled the production table off my 15" delta, I was caught off guard. Realize I'm ~5'7" 175lbs, pulling that SOB off the column standing up was not fun.You could say that again.
The drill press pictured, as it sits, weights in at ~380-400 lbs. VERY top heavy, use caution when moving.
, i would bring a couple buddiesHow many speeds? Does it have an intermediate pulley? I see what could be a table elevation feature?
If yes to all of the above I'd go $300 if it's in good condition.
If it's only 4 speeds and no table elevation then it's generally a woodworking DP and I'd go $100-150.
The mobile base is a plus too!!
This is probably the last drill press I'll ever buy, and as others have already said, it's very heavy.
Jim C.
Just wait. Post a pic of your machine if you can. Sounds really nice.
You say that now.Just wait. Post a pic of your machine if you can. Sounds really nice.
No, this is it. This drill press has been a "quest machine" for me for several years now. I don't have the space for more than one. The motor needs bearings and a new switch and switch box, but that's about it.
Jim C.
That is a very nice machine. The table looks flawless.
Do you have the switch rod for it?Yea, keep telling yourself that.That is a very nice machine. The table looks flawless.
By the way, my drill press did not come with a switch rod. I mentioned earlier that it needed an original switch and switch box. I have both parts. If I didn't have those parts prior to buying the drill press, I might not have bought it. Also, you're right about the production table. It is in very good conditon but has four very small divots. If it had a noticeable "arc of shame" or through and through holes, I would have passed on the drill press all together.
Jim C.
What other delta machines do you have? If you ever want the dimensions for the switch rod let me know. I could take some dims off mine if need be.
Are you on OWWM by chance? Yea I saw where you said about the switch and box, but didn't see anything mentioned about the rod and holder.What other delta machines do you have? If you ever want the dimensions for the switch rod let me know. I could take some dims off mine if need be.
That's a Delta 17" drill press. It's one of the strongest and best drill press models Delta ever made. There was never an intermediate pulley option for that model.
5 speeds, either low speed range (approx. 385-2600 RPM) for metalworking or high speed range (approx. 770-5200 RPM) for woodworking.
Since it has the #2 Morse taper spindle, it's probably the low speed model for metalworking.
If everything is operating as it should, easily worth $300. Less for missing or damaged parts.
what is table elevation and why would I want it?
Also, I see the table on this is solid. All the other presses I have owned have slots in them...of course I never knew what they were for either until I just got a freebie Craftsman milling table that can bolt into the slots.
I still may go grab this tomorrow. Couldn't grab it before as I didn't have any help to load it before.
It is a very good press, just check it over thoroughly.
Don't think of trying to transport it standing upright like that.
