Cord guage on drill press
Dansdad
concord,ca
I was reading the amps on a craftsman was 3.2 but the cord was 18ga. This seems extremely small .What I removed it and replaced with 12 ga. Would that help?...Thanks Dave
Norcal
Sometimes too big is worse then the correct size, 18 would be fine & 16 is fine too, smaller motors are not blessed with oversized terminal boxes, using 12 gauge is like trying to stuff 10 pounds of manure in a 5 pound bag. 3.2 amperes is not a large load.
nehog
Jaffrey, NH
18 AWG is fine for 3.2 amps. No need to re-engineer the machine. ;)
Gary S
Bismarck, ND
Stranded wire can be a bit undersized for short runs like power cords because it handles current better than solid wire of the same size.
Original size is just fine.
Norcal
Codes do not differentiate ampacity between solid & stranded wire.
2ManyProjects
That's an Old Wives' Tale.
The ONLY thing which determines current capacity (a.k.a. "ampacity") is the cross-sectional area of the conductor(s). And at least under the AWG scale, the "waste space" between strands is already accounted for, as the AWG number considers ONLY the actual conductor area, not the gaps (if any). Hence, stranded AWG 12 wire will be somewhat "fatter" than solid AWG 12 wire, but provides EXACTLY the same cross-sectional area.
All that said, at EXTREMELY high frequencies (in the multiple MHz range), most stranded wires will exhibit somewhat less attenuation than equivalent-size solid wires; but this has nothing to do with ampacity or "current capability".
nehog
Jaffrey, NH
Only when dealing with high frequencies, not for power line voltages/frequencies. This is an 'old wives tale' that needs to go away. Stranded wire offers flexibility and nothing more when used in AC power applications.
nehog
Jaffrey, NH
This is known as 'skin' effect, where more current flows along the skin of the wire than in the core. But in the end, the current balances out, leaving just exactly what 2ManProjects says--the current capacity is the same regardless.
DenisG
Milwaukee
You probably should look at the nameplate of the motor and see if it tells you the FLA (full load amperage) before being concerned. I'm guessing that you measured the idling current of the motor.
