Building tripod stands
A
alan camby
South of Indianapolis, Indiana
I did notice where he mentions what you're referring to. I was looking for additional information, guess I should have been more up front with what I was looking for. I can't tell if it's a slab from an old piece of tooling/bench, or if it is simply a giant piece of 3" plate welded to an engine stand. :lol:
Scott
Edit: For example, in this picture there appears to be a tag of some sort affixed to the front of the slab.
It is just a old ground flat table that came out of a factory. It is not solid but webbed cast iron. Still very heavy.
And yes it is mounted on a engine stand.
It is not welded to the stand. I used the four adjustable mounts on the stand to attach the plate with bolts. I drilled and tapped the holes in the back of the plate.
mikegt4
sw ohio
I have had good luck purchasing ACME threaded rod from Roton Products. It was much cheaper than Mcmaster or Enco (although there is no such thing as cheap ACME).
http://roton.com/
Seiler
Colorado
Gothca. Thanks for sharing! Makes me want to order a huge chunk of plate and make something similar. :lol:
Zork
What finish is that on the rod & nut? Stainless, Low Carbon, Alloy Steel or Oil finish?
Thanks
:bounce::bounce:1.5" ACME threaded rod. That is a 1/2"-13 nut below it for scale. The platform is 2.5"x4"x1" thick.
saceone
Montreal Canada
that was a great read! I really enjoyed it. Great project and love the attention to detail (read: your welds are nicer than mine by two football fields, and CFL football fields on top of that)
davin24
gotta have these
sell sell sell them!!! too nice of a product and usa made!!!!!!
joeswamp
Massachusetts
These are just too nice of a product -- someone needs to make them.
Although I must admit that I would not want to be on the receiving end of the lawsuit when some idiot attempts to use one to hold up a railroad locomotive.
zkling
I made a set a while back after getting frustrated with the off the shelf offerings. A tip to save money on them is to forgo the threaded rod and nut and just make them at a fixed height, a few inches under your jacks max lift height. I settled right at 16" which is more than enough for most common vehicles, especially unibodys.
