Snap-on GF80 - $40.60 Shipped - New
Hoot
Huntsville, Al
Man!!! I almost pulled the trigger on that. But I already have an F80 (which I got from one of Merkava's other posts - Thank You!) so I couldn't really justify adding it to my ratchet collection. I'm sure someone else on the board will give it a good home though.
98riv
I bought it. It will be my first snap on ratchet. Thanks for posting the deal Merkava!
wrenchr
Roger that...
But if it's anything like the finish on Snap On's impact sockets, that ratchet will have surface rust in no time...
Not really I have about 5 snap on industrial ratchets and I spray them with oil once it gets cold.
eschoendorff
Hmmm... gives me an idea. My wife was just complaining that she was cold. Maybe I should spray her with oil....
please, NO "red lube of love" comments. KY is clear. :thumbup:
wrenchr
Merkava is going to get you because you did not change the font color to red!!:lol_hitti
98riv
What are your current ratchets? I'm sure this will put them to shame!!
Raised panel Craftsman ratchets and a Gearwrench ratchet (the one that comes with the spark plug kit). I am looking forward to trying it out.
wrenchr
Cool, please update us with your thoughts when you get it!!:beer:
98riv
I just got it today, so I haven't had a chance to really use it yet. But so far, I really like it. It has a good feel to it. I can see why people like them so much.
a390st
Be sure to keep it oiled. In high humidity they can develop some surface rust where the finish gets thin. It will sort of get rubs in the finish after a good bit of use. Actually, that is an observation from other brands of industrial finish tools. I've never had SO industrial finish. It is a very good ratchet, though, and you'll never have a problem with chipping chrome. It's a lot better than any of your other ratchets.
Merkava_4
Clovis, CA.
98riv,
The finish may seem a little rough right now, but it'll smooth out after awhile with use -- and you don't have to worry about scratching the chrome. Keep it preserved with WD-40. :thumbup:
a390st
Take it from me, unless they are totally different than other industrial finishes, you'll do well to keep it oiled. I don't like WD-40, but it would work. There is a reason industrial tools exist, and it isn't just a matter of expense. Peeling chrome is a very bad thing. It will slice you like a razor. Just be careful not to lose it. That's actually one of the reasons chrome is nice, in my opinion.
krusty the clown
Member Emeritus
niangua, mo
WD-40 is 20% fine grade machine oil .... I learned that from A&P school. :D
it also contains eyther that will break down and dry out the oil........i learned that from collecting firearms :spit:
i hate to have to remove rust from something i just applied a rust preventative too...........:thumbup:
a390st
I used to work as a gunsmith and have spent hours and hours cleaning dried WD-40. It dries to a shellac like "crust" that takes real work to remove. It is a fair rust preventative, but I would just use a light oil instead.
a390st
Anything that's just oil would be alright. Light machine oil, motor oil, vegetable oil, even ATF or CLP would do. All you need to do is wipe it on and wipe it back off. It doesn't need to be dripping wet, just a very light coat. I just like a good light machine oil because it won't smell bad, won't turn rancid, and won't be too full of chemicals.
a390st
I like Ballistol alright, but it doesn't protect quite as well as a pure oil like Rem Oil. Ballistol uses mineral oil, which is good, but it has some non-oil components (e.g. isopropyl alcohol). I wouldn't be afraid to use it at all, I just like Rem Oil because it doesn't stink and has a higher percentage of oil.
