redwrench60
I picked up a good condition used Dewalt 7" 15 amp angle grinder (not a China or Mexico made one) and I'd like to grease the gearcase before putting it in service. What to use?
I use Lucas red n tacky #2, it is my general purpose shop grease. Every year I repack it. Keeps it running smooth, and I show my grinder no mercy. Was using it a few hours ago actually.
Can you post a pic of your grinder? Roughly how old is it? I'm curious on the COO now that you mentioned it. Is it one of the older metal case one?
Seriously it's a stout beast, runs good and the price was right. Don't know exactly how old it is but this particular model has been discontinued.Dewalt recommend Polyurea grease for high speed heavy loads....google is your friend.
Think I'll stick with my red n tacky. YMMV
Any grease is better than the little to none they put in at the factory. And use the guard on it...
Polyurea grease is used for electric motor bearings. Check with your local electric motor rebuilder. Phillips 66 makes "Polytac" polyurea grease in standard and EP (extreme pressure) varieties.
Edit: It looks like John Deere is a source for polyurea grease: http://www.ebay.com/itm/Mini-Grease...799?pt=LH_DefaultDomain_0&hash=item3cd0d7e9df
Was I asking too much work of you to post the link?
http://www.ereplacementparts.com/grease-oem-p-90565.html
$30, are they serious?Think I'll stick with my red n tacky. YMMV
Yeah, lm sure it will be fine.Was I asking too much work of you to post the link?
The proper lube for a high speed spiral bevel gear like this is NLGI 00 grease. Specified by Black & Decker industrial service document prior to Dewalt's takeover.
http://www.amazon.com/gp/aw/d/B001OKBHRK/ref=aw_d_pd_lawn-garden
Smallest reasonable quantity I found, no need for 55 gallon drum
Too heavy (like NLGI 2) and it won't drop the oil which is what is required to lubricate. Fill approx 1/2 full. Too much and it will churn excessively and overheat, draw excessive current. More isn't better with gearboxes.
Can someone post a picture of what yall are greasing because my grinders are loud and if I could do some preventive maintenance to keep it going for a long time would be great. THANKS
Can't say I've ever used grease , or a guard, on any of mine!![]()
Im with you.. never even thought about it and I abuse mine. But then again it is a hilti...
