One potential reason why this thread may appear as if we are "going to war" is due to several suggestions to use "galvanized steel" or "galvanized pipe". While galvanized materials may offer more corrosion protection, they are not good for compressed air systems.
Galvanization works by virtue of the sacrificial zinc coating. Key word: Sacrificial. The zinc that is sacrificed ends up as white stringy residue in the air lines. It fouls tools and air lines, and is difficult to remove.
There is a reason why professional, industrial, and commercial organizations spend thousands more on purpose built aluminum tubing systems for compressed air. If galvanized pipe were acceptable to be used, there is no doubt that companies would make prevalent use of it to save money. But they don't, because the damage the floating zinc byproduct makes to the systems served by the air costs more in repair and remedial action than the installation of more expensive piping systems.
Even black iron is preferred over galvanized. Yes, black iron may corrode faster, but it doesn't contaminate the air system with zinc sluff. Looking for patterns among the best practices of the military, manufacturing, medical implementations, and many other engineered and approved installations of compressed air systems, one will not find any galvanized piping involved.
However, one can also see quite a few DIY home and small service shop air systems using galvanized pipe. Naturally, the choice of which pattern to emulate is up to you.
