when do you use pliers vs wrench / sockets
PoorOwner
CA
Doesn't the pliers marr up the fasteners a bit?
On the other hand, maybe pliers are used to removed rounded ones?
What about visegrips, do you consider it just another plier style?
quad shop
ellensburg washington
Senior member 1688 posts. :headscrat
Anyways as a absolute last resort on some thing that is compleatly rounded. Sockets and wrenches where made for a reason to take nuts and bolts apart. Pliers and vice grips where ment to hold stuff
P
PoorOwner
CA
Its because I have never really used pliers to take anything off, except for some stripped flare nut on a brake line, after someone didn't use a flare wrench, I guess..
So just got me thinking, how important is it to get good quality pliers?
P
PoorOwner
CA
Also, have you been to some one's house to fix something, their only tools are a hammer, a linesman plier, a needle nose pliers. Sometimes they have a cordless drill, but it only has 1 drill bit. :) and if you are lucky, you will find a single pair of channel lock pliers
CodyY
Fort Worth, TX
Wow.
CWP1616L
USA
You use pliers when there's no flats left for the wrench or socket to grab onto. After you get the fastener off with pliers, you throw the fastener away.
nicksnothereman
In the Mojave
If I'm replacing a fastener and can't get anything but pliers in there I'll use pliers. I'll round the hell out of them both coming out and going in; I'll try to use an open end on it going back on usually it'll go on no problem. Yeah that leaves me at square one sometimes but for the fact that a new fastener is usually in better condition than a ten year old one. Sometimes it's a **** shoot. If you f- up you're out a buck or two.
Why you think I'm looking for kiwi pliers boss?:bounce:
nicksnothereman
In the Mojave
I think super high end expensive pliers are a waste.
If you're an electrician I'm thinking they're not. Good pair of needlenose an electrician would probably give their first born for.
For a mechanic...you need them sometimes but usually there is more than one way to get stuff done. Usually the pliers would be last resort territory.
The Muffin Man
Mercer County, NJ
As someone who deals with large and small electrical work frequently, I strongly disagree. The pliers that I need have to be precise, not have any play in the joints, ergonomic, and of course durable. Searching high and low only a very select few brands meet these requirements and rest assured they are super high end and very expensive. But they are worth every penny.
If I'm dealing with a fastener, never. If it's stripped then one form or another of vise grip generally, and no I don't consider vise grips to be "pliers"
I DO use different breeds of pliers a lot, for forming things, for holding things (think wire wheel or hot, or welding at times) for electrical or electronic work. For squeezing things together, etc... Having the best set for the purpose makes for a lot less frustration over trying to use "compromise" pliers, so I have a LOT of pliers, in endless configurations and styles. Just the difference between long needle nose or shorter ones depending on the need is night and day...
And the difference between cheap pliers and good ones is no different than any other tool. Good pliers do the job better. Again, less frustration.
Adam.C
In my experience, vise grips generally destroy whatever you attach them to. Working on cars, I use the heck out of my duck bill pliers, tho I couldn't honestly tell you what I use them for.
My initial attempt is always sockets, wrenches always come second.
Knipex plier wrenches deserve a special category. They are the worlds best adjustable wrench and can rival a proper open end at times (because you can squeeze the fastener I.e. zero play between wrench and fastener).
Every other plier is a tool to help you hold something awkward. That's not say that isn't an important job. I think expensive/good quality pliers destroy stuff less than cheapies.
ddawg16
S. California
Right tool for the right job......
About the only thing I use pliers for is to hold something while I'm grinding on it.
billp603
NH
PVC threaded fittings are another spot where I use Channellock type pliers around the house. Cleanout plugs, the nut on a p-trap, 2.5+ nuts and fittings around swimming pool pumps. Not a lot of torque needed for any of these applications.
losabio
<iframe width="420" height="315" src="//www.youtube.com/embed/_MgAHe-rLQo" frameborder="0" allowfullscreen></iframe>
P
PoorOwner
CA
The knipex wrench pliers is on my list, it would be handy to install air fittings and pressure gauges.
Haveblue
kansas
I prefer the right tool for the job, but I have one of these. It does come in handy at times! 41v3IO4MfDL.jpg
CodyY
Fort Worth, TX
The correct answer is to TIG weld a nut to the top of the damaged fastener and remove with the proper socket.
Duh
m4rkz0r
Texas
Duh
False! Air hammer solves all problems.
My boss has an Integra he's been restoring. He seems to use an air hammer for freaking EVERYTHING. It boggles my mind. If anyone knows what the "***** pin" is on a honda shift linkage, he told me he removed that with an air hammer. There is now a running joke at the shop if you're ever having a difficult time with absolutely anything and you ask me for advice, I always recommend the air hammer.
But on topic I never use pliers for nuts or bolts with a few excetions. For rounded fasteners, gripping the nut on a through bolt, and sometimes when adjusting tie rods.
djwyman
only time I use pliers on a nut or bolt is A. if it is already buggered up and a socket or wrench won't take it off, or B. when I had my motorcycle and I was broke down on the side of the road the leatherman might come out if it was something I could fix or at least rig to get me home.
markw365
Like my dad always said, proper tool for the job. Pliers and vise grips are not the proper tool for the job unless that job is holding a couple pieces of metal together for something, or removing a broken/rounded bolt.
If he caught me using a crescent wrench on my bicycle I'd get a lecture, especially if I was using it with the jaws pointed the wrong way. That is a double whammy, first, why are you using it the wrong way, then second, why are you using a crescent wrench when you should be using a wrench.
