HotRodHudson
- Joined
- Nov 18, 2013
- Messages
- 373
Hello all,
As one of my first threads, I would like to ask for some suggestions, advise, etc on the installation of a sub panel in my garage. I have already done lots of research on-line, sometimes successfully, sometimes not. However, another set of eyes or "I've been down that road before and....." would be helpful.
So Far:
The current Load center for the house is 200amp and I am bringing a 100amp sub panel to the garage. The new sub panel is a 100amp square d, Homeline (HOM24M100VP) 24 spaces & 24 circuits with main breaker factory installed. I have already run 2,2,2,4 aluminum service entrance wire to the garage. I will run 12 gauge for outlets and lighting with 20amp breakers. 10/3 for the 30amp locations and 6/3 for the 50amp location. I also have room in the main (200A) panel to add the 100A breaker needed for the connection to the sub-panel.
The areas of concern or question:
Bonding the Load Center: While I have read this is what needs to be done since the garage is attached to the house I am not 100% sure how to do it with this box. I understand the neutrals need to be completely separate from the grounds, so I have purchase additional grounding bar. Im just not sure where to put the grounding bar and the green screw that came with the load center? Does the green screw hold my new grounding bar in place or does it go somewhere completely different?
Fire blocked wall Location: while the wall the load center will be installed in a wall (stud cavity) that has fire blocks, my city electrical inspector told me today there is no problem going thru the fire blocks and since they my local area doesn't consider it a fire wall, I don't need to fill gaps around wires going thru the blocks. Not to get into a debate on if that is good or bad, what suggestions might one have for running wire thru the fire blocks? It is an insulated wall with an open attic above. One idea I had thought of was to drop down inside the 2x6 stud wall some plastic electrical conduit to provide easy access for running wires, maybe a couple 2-3.
Data Center next door: the data center box which houses the Ethernet, phone line, cable and my wireless router, is in the cavity directly next to the one I am planning on using. Will this create issues or be a problem this close?
Water below: If I use the planned stud cavity next to the data center box, then I am 6-7ft away from the water spicket (sp?) However, If I move the load center box away from the data center box one option is to put it in the cavity above where my Hot & Cold water come into the garage, spicket. The water comes Horizontally in & would be at least 4-5 ft below the load center. How close or far should I be from a rarely used water source?
Planned circuits: Right now I am planning on 4-30amp (air compressor & car lift take two, so a couple others would be nice for future needs. also planning on a 50amp for future too. Lots and Lots of double outlets with some 15 & 20amp recepticals. Then comes ceiling lighting, of which I still am dragging around 14 new in the box, Metalux Cold weather series (they start down to 0 degrees F!) 4ft, 2 t12 bulb units will be used. Yes, I know they are t12 but I already have them and since they are still in the factory boxes, I might as well use them. I haven't nailed it down yet but I have been looking at Phillips t12 bulbs which are 40watt, 6500k, CRI 84, initial lumes 2324. I wish it had a higher CRI rating so I am open to suggestions. I figure each light will need its own electrical box in the ceiling to be code, but not sure.
So hopefully I have provided enough information and naturally I am open to suggestions about all the things I am doing, especially things I cannot for see I will need in the future! P.S. I want to stay up to code on things if at all possible for the safety of my family!!!
So Far:
