Dugan
I'm prob going to be using 8 Gauge wire. I was going to install atleast two receptacles one by the "Future" lift and one by the door.
I know stranded is better/easier to move/larger than its solid counterpart, but is putting stranded into breaker panel a PIA? Would it be better to run a small solid down to a junction box below the panel and run the stranded from there? *Ive only ever worked with Solid in houses*
Im an electrical engineer.. Go ahead flame.. I have experience with wiring homes/cars etc but its the small things I'm unsure of. So I thought id post to get your ideas.
Also, the welder and Plasma only draw about ~30A and have the 2 spade 1 round 30A plug, but its easier to find the 50A 4 prong plugs around here. Lowes is always out of the 30A for some reason. So i Was going to install the 50 with the extra outlet incase I have something in the future that can use it to have a versatile outlet. Any problems running the higher breaker? Or should I keep it at 30A for the overload protection.
