schor
So I made one.
I put it to music, hope you enjoy.
So I made one.
Very nice
I have made replacement draw bars as well when I have needed to
I get round stock the size I need formthe bar. Thread the end, then I take the hex stock and drill the center out. Heat it on the BBQ a bit to slip it over and rosette weld the end.
Same trick making the piece longer so you can shorten as needed
Bob
Good job.Only suggestion I could make would be when you are centerdrilling sock for the center. Be carful on long, unsupported piece like that. It is best to chuck it up close in the chuck, face, center drill and then pull the piece out for it to sit in the tailstock center. Minimize runout and saftey, chances of the bar bending and becoming a spinning hazard. Looks like you are all ready for a DIY power draw bar, just get a butterfly impact and a method to rig it up. Neat little mill.
