DPDISXR4Ti
Maybe an adapter will be available soon?
http://for-sale.yowcow.com/listing/30344728/
How do you even reply to this ad?
I'm okay with investing in a new 20V charger if I have to, so really, this isn't a problem for me. So you see, there is revenue for Dewalt in this - I'd buy new 20V batteries and a charger, if only I could use the 20V batteries with my existing collection of 18V tools. And then there's future 20V tool revenue as I move forward as a happy Dewalt customer.
Such a tab would have to be on the battery, though - and such a tab that would prevent installation in an improper charger would also block installation on an older tool.
I'm going to have to talk to one of my subs who has a bunch of old+new DeWalt 18V stuff, and take a look at the stuff, because I don't see how they could work that.
Not dewalt ones, but yes I've disassembled laptop Li-ion packs and the multi-finger connectors (see attachment) are used on those to expose the individual cell voltages to the charger.Honest question: How do you know what the old and new packs have? Have you disassembled them?
I was just referring to them keeping this extra charging logic internally within the pack so that they could make them physically compatible and make dual chemistry chargers etc. Without the need to externally expose the intermediate cell voltages or other sensing information to the charger.I'm also curious what "bridging measure" you're talking about. The Li-Ion or Li-Po cells output DC power, correct?
so if what you are saying is correct and what i have suspected is that the smart capability is only for charging, not for usage. if so that would mean there would be no issues running an older tool with a 20 volt max battery.Not dewalt ones, but yes I've disassembled laptop Li-ion packs and the multi-finger connectors (see attachment) are used on those to expose the individual cell voltages to the charger.
You can see these "fingers" pretty clearly on the attached image of a dewalt 20v max pack. Each of those "c1" ... "c4" are most likely the intermediate cell voltages from the four series interconnections between cells in a five individual cells in the pack.
Because these Lithium based cells are much more prone to fire or explosion if overcharged they need more logic in the charger and/or pack to control the charging. One way or another the charging circuit needs to know the individual cell voltages (eg 3.9 or 4.0 etc volts) and not just the overall pack voltage (eg 19.5 o 20.0 etc volts). Otherwise if (or actually when) the individual cell capacities diverged you could have one cell overcharge and explode on the charger, even though the overall pack voltage was within spec.
Old nicad packs didn't need this. If one cell was much more fully charged than the others in the pack then the charger didn't know or care, it just proceeded to overcharge and slightly cook that cell while bringing the overall pack up to charge.
It might be different on other brand tools, but on both of my Li-ion drills there is only two connections (positive and negative main power terminals) between the battery and the tool. In this case the run time protection can *only* be in the battery.I know if you overheat the batteries in the newer tools, they shut down the tool. Not sure if that's the battery or the tools job tho.
Not sure yet, still trying to figure that one out.
I need to look back in my history and see what page I linked to before that one to see if would offer an idea.
I traded messages with the guy who makes these and he has already looked into doing precisely what we have been discussing here, but there is a problem. Apparently the Dewalt Lithium Battery is rigged electronically to only work with the new Dewalt Lithium tools. I think the primary issue here is that the required (for Li-ion batteries) shut-off circuitry is in the Dewalt 20V tool rather than the battery.I did find a similar Makita adapter:
Makita adapter
I emailed the seller and inquired about one for Dewalt, maybe he can source one if he is just a reseller or produce some if he makes them.
Dewalt wants you to buy new stuff like everyone says. The funny thing is kobalt 18, 20 and lithium interchange. Check it out at the store sometime.
Doing some more digging, this thread confirms that the "20V" Black & decker and Dewalt product lines are incompatible...
http://dewaltownersgroup.com/index.php?topic=1038.0
As the Dewalt employee confirms, the primary issue is the location of the shut-off electronics, and for the Dewalt 20V stuff it's in the tool.
It seems that despite this everyone is taking his words as gospel???I have no official knowledge on this subject, so keep that in mind when reading this.
Anyway the specific issue he refers to is that of over current shut off, not under voltage or discharge shut off which some people seem to be confusing it with.
Ok yeah I think you're right. It looks like both under-voltage and over-current and/or over-temperature are all moved to the tool.Ah, I certainly came to the conclusion that it was the low-voltage shut-off function that had been moved from the battery to the tool with the Dewalt 20V stuff. So perhaps I jumped to worse-case scenario too quickly, and what they've done is added an extra layer of protection that simply doesn't exist on the lower-end B&D 20V stuff. But even still, if that makes the two product lines incompatible, it's an overall negative from my point of view.
I'm done with DeWalt.. probably going Bosch the next time around.
i think an adapter that uses anything but a mainstream battery and more precisely a 20 volt max battery is a waste of time for several reasons.
The only issue there is that none of those lines are particularly mainstream or top-tier.
You want a battery source that's going to be around for quite some time, and not immediately discontinued and replaced if some bean-counter feels sales aren't quite up to snuff.
I could be completely off-base here, but neither the B&D or Porter-Cable brand of cordless tools really seem to be widely popular or distributed. The Craftsman 20V stuff is second-fiddle to the 19.2V stuff.
Relative to the guy at www.liondapter.com making an adapter, I believe you are mistaken. From my discussions with Russell, what he plans to do is make an adapter between the Dewalt 18V and Makita 18V. My suggestion to him is the same one I've made here --> an adapter between the Dewalt 18V and B&D/Porter-Cable/Craftsman 20V Max.
That's what i said 2 months ago. I went to milwaukee Fuel and am very happy i did!
if you are done with dewalt you will be done with bosch next. they ****.
go Milwaukee or makita if you are going to make a change.
Elaborate on your position?
They are on the short list also.
Love Bosch's new impactor with 1/2 socket and 1/4 hex.
Their radio also sounds excellent![]()
My impression is that the Craftsman 20V Max line is going to be replacing the older 19.2V stuff, much the same way that Dewalt has moved from the 18V to 20V Max lines.
