Ratchet Question -- Craftsman and Snapon
bomber
Group W Bench
All -- I straightened up the roll cab the other day, and realized I have no clue what these things may be --
First is a Craftman 3/8 ratchet --
Marked, oddly enough, "Craftsman" on one side
And "Forged in the U. S. A." on the other
ON the same side, there is what appears to be a capital "U" enloced in a circle to the left of the "Forged" legend . . . . .
The old gent wasn't working very well, but popping open the works, a good cleaning and some lube has it right as rain! Dates -- any guesses?
Second, and perhaps a bit more important, to me, is this Snapon 1/2 ratchet . . . . .
I was using it to threaten the 31 Ford last weekend, and went to select "OFF," when I noticed something wrong . . . . . .
Damn! I have very few SNapon tools, and this one is from a late friend -- I was, er, distraught -- proving, once again, that I am the luckiest of men, ten minutes with my magnet on a stick produced
It slid home nicely, but shows no sign of how it should be retained in the mechanism (I did take iut apart and clean.lube it, but I saw nothing that seemed interested in fastening to the lever).
The ratchet is marked withe the logo, "USA," "PAT3713356." (Pat sure gets around, doesn't he?). There is also what I assume to be a part number, "S713A."
Two questions -- how do I make certain the lever doesn't jump ship again (I am not counting on my luck running quite that good again), and when was this gent produced?
Thanks for any assistance you may be able to provide!
Lastly, have a great Holiday!
pl_silverado
West Bradford, PA
First of all, i think someone rebuilt that snap-on ratchet and put it together the wrong way.
Second, put the selector lever back in, place it against something flat and solid and peen the other end.
v8garage
Texas
The Craftsman ratchet pictured was made by Plomb in the early 40's and uses the same mechanism as the war era Plombs pictured in the attached photo.
bomber
Group W Bench
thanks, all -- you'll be happy to know the Snapon is now properly assembled (brain fade on my part after the struggle to get the little ball into the sletor mechanism).
v8garage
Texas
i think the craftsman was made by duro/indestro. i don't think proto ever suppplied sears but i could be wrong.
See post # 4 please. :confused:Let me reiterate that it is an established fact that the Craftsman in question was made by Plomb. I have a Craftsman ratchet exactly like that which belonged to my father. The lever was broken off of it and I used the guts out of a WF Plomb to rebuild it. The cover plate off the Craftsman even had a Plomb part # on the back side when I took it off. :thumbup:
krusty the clown
Member Emeritus
niangua, mo
well....i used the words "i think" and "IIRC" for a reason :bounce:
while i have never owned a proto ratchet or seen one like that, i based my judgement from seeing duro/indestro with identical reverse levers. like this one on alloy-artifacts............
perhaps proto contracted the WF series from duro OR duro contracted their ratchets from proto since that has been common over the years. we will probably never know. i did look at lauvers thread and sears DID contract some production from proto (46-48?) and i was unaware of that since it was way before my time :lol_hitti
pfbz
Posted before, but worthy of a repeat! Agree, 1978 on the SO. And backwards.
kartracer55
The ratchet is definitely interesting. Can you grab a picture of the other side of the head for us?
Traditionally, the drive end comes out of the other side of the ratchet, through the removable cover plate. Then, on the side where it says "on-off", there is a little sheet metal cover that fits tightly in there.
You can buy a complete rebuild kit that will come with new guts and a new sheet metal cover for you to press in to the top of the ratchet. Also included will be a new reversing lever. As was stated, the reversing levers are peened in place. so you stick the reversing lever all the way in, flip the ratchet upside down and essentially mushroom the stem side of the reversing lever to hold it in.
Jim
bomber
Group W Bench
Kart -- it's only interesting in that I assembled the poor thing backwards (for which I blame my attendance of the New RIders of the Purple Sage concert in 1969!) . . . .
I did pein the lever in place, and all is well with the wrench -- thanks, all, for the information!
PFBZ -- I can (sorta) read the SO date codes, but I'm confused -- where on the ratchet would one find the code?
thanks, again, all!
Uncle Buck
Kansas
I found one of these in primo condition 1/2" drive size about a month back for something like 6-7 $, Yea it hiched a ride home in my pocket for that price!
MOPARHOUND!
Kansas City
thanks, again, all!
The date code on this ratchet is the number 8 stamped between "ON" and "OFF"
Match the Script/Font style of the 8 to the decoding charts, and it decodes as a 1978 model.
