1/2 Cups Brake drum pot belly heater build.
1/2 Cup
Member Emeritus
Shepparton. Victoria. Australia
I guess heating your garages would be fairly topical at the moment so I thought it was time to share my pot belly build I did last summer.
Its not that I really needed a wood heater in the shed as it has reverse cycle air conditioning anyway, but came about after seeing a few of my mates building them for their garages and saw it as a challenge to firstly go one better and then build one with character and charm.
I have got to fess up to having a soft spot for all things "old cast iron" and that's where the inspiration came from.
I will let the pictures tell the story. As this is my first thread that I have started about the stuff I do please bear with me, hopefully it will be the first of many.
View media item 35125I purchased this old Windsor unit from my brother several years ago in the hope I could resurrect it at some point as I loved its classic lines but was in pretty poor condition.
In the meantime I was offered a couple of brake drums from a low loader that were going for scrap and promptly snapped them up as you do, they sat at home for months until my better half kept asking what I was going to do with them and to put in to her words "the place is starting to look like a recyclers yard". Done deal I will build a heater! just because I can.
I don't do plans, well maybe the odd sticky note and loads of inspiration.
It started with the base, as I had an unmatched set of cast iron display cabinet feet that just screamed out "repurpose me please" and some 3/8 and inch plate that a mate did some circle work on, I don't own a plasma cutter, just a gas axe and several grinders.
View media item 29628View media item 29626
I "found" some railway sleeper cleats that I used for additional support behind the feet.
1/2 Cup
Member Emeritus
View media item 29623The ash tray and door assembly.
It was basically hewn out of a short piece of 12 inch x 3/8 pipe with some decorative rings added for character.
The door hinge was made from 3/4 shaft collars stitched in place with a removable stainless hinge pin.
View media item 29636
This pic shows the preassembly of the base to the bottom drum.
I fitted 2 x 1 inch mild steel dowels to locate the drum centrally on the base using the lug nut holes.
1/2 Cup
Member Emeritus
View media item 29638
Cutting the hole for the flue proved a bit of a challenge as I don't have a plasma cutter.
I made a template and carefully scribed the out line due to the curves, drilled a series of holes the basically used a jigsaw to do the cutting between. I was surprised just how effective it cut the cast iron at low speed. I then dressed it up with a 4" as I am using a 4" **** weld elbow to transition to the flue.
theoldwizard1
SE MI
I had no idea the brake drums on trucks/trailers were THAT ENORMOUS !
Great job cutting that hole for the flue !
1/2 Cup
Member Emeritus
Thanks for the feed back guys.:thumbup:
Our temperatures range from plus 40 degrees c down to below freezing. It does not snow where we are but comes pretty close at times.
We are into spring at the moment with temperatures ranging from a cold 10 degrees c
up to a very comfortable high 20 degrees c during the day. From here on in we can get some pretty warm to hot days, air conditioner time believe me.
Its fairly cool and overcast here this morning (Sunday 24th), jumper weather.
1/2 Cup
Member Emeritus
I have decided not install the heater in the garage and it will ultimately end up in an undercover out door BBQ area.
A mate of mine has some 4" stainless tube that I will use for the chimney and a neighbour picked me up a suitable cowl that was in really great condition at a garage sale a few weeks ago.
I am using a 4" sch 40 long radius **** weld elbow that will incorporate a "throttle choke" and have machined and welded in a transition piece to adapt to the chimney.
The main reason for this is the heater is fed through the hot plate opening and I did not want to inhibit the opening in any way.
Very much like the Old Windsor I have.
1/2 Cup
Member Emeritus
View media item 29639
The "throttle choke shaft" and butterfly.
The shaft is 3/4 " mild steel rod that I slotted by hand to fit the butterfly as the mill at work was out of action, damn near a days work mind you!
The butterfly is 1/4 " thick, cut over size and will be hand fitted to the **** weld elbow so that the seating angle sits nicely .
View media item 29640
The butterfly locating screws.
View media item 29936
Assembled, ready to tack and weld the shaft collars in place.
ambenz
NW Chicago Suburbs
Lots of great ideas here to upgrade my outdoor patio chimea.
Subscribed!
I just love the feet and base, the beefy ash door and vents.
I can just imagine what your gonna do for a fuel door!!!!
The grate is nice and strong looking too.
My pot metal grate broke this fall, I'll be commissioning a new metal grate in the spring, maybe like yours.
Awesome build so far...can't wait to see a few hard wood logs turning the sides cherry red!!!!
1/2 Cup
Member Emeritus
man .. you don't mess around .. that thing is awesome :bowdown:
how much for one shipped to NJ USA? Ha just kidding. Really nice stove though. How cold does it get where you are?
Subscribed!
Thanks very much for the feedback.:thumbup:
The fuel door is through the opening under the hot plate which simply slides to one side and you drop the wood straight in.
The grate was fairly simple to build, I tend to over do things at the best of times. I kept things as simple as possible, easy to remove and replace if required.
I learnt a lot from pulling apart the old Windsor heater.
The other thing I think is a must is to clean it after use and not let the ash get damp which seems to really eat into the metal.
1/2 Cup
Member Emeritus
What a great piece. I wonder if you looked at mine that day you called ?
Still I like those legs. Every Aussie Shed needs a Truck Brake Drum heater :thumbup: .
I am always on the lookout for ideas, better ways of doing things and inspiration. And yes, your heater was duly noted.:thumbup:
I picked up another set of legs (6) at the Cobram swap and a die cast set from Ebay recently.
1/2 Cup
Member Emeritus
I think I need to repaint mine this summer as yours looks so good. I'have to post a photo of my outdoor heater as it is a round metal basket out of a waste drain system with legs similar to what you have used. Yes my heater needs a coat of paint :eek:.
Post a pic of your outdoor unit - always looking!
Mine could be used as a fire pit as well by removing the top drum.
I tried heat proof paint, cost $18/rattle can followed the instructions to the letter - HUGE FAIL,
In the end I have just used stove black, somebody even suggested black nugget???:headscrat
Jim_No_Garage
Millington NJ
View media item 35440
The hot plate handle arrangement - finished and Shelby the garage guardian.
I'm blown away by the skills represented in this thread. That is an awesome stove . . . Thanks for sharing and hopefully encouraging further creativity.
Shelby looks like she wants the heater lit so she can plunk down on the ground nearby and bask in the heat. Is she a specific breed of dog or just a mix?
Cheers
Jim
1/2 Cup
Member Emeritus
Cheers
Jim
Thanks Jim for your comments.:thumbup:
Shelby is a Belgian Sheppard, she is an extremely high drive kind of dog, loves in the shed and gets pretty creative in moving stuff around if you do not pay her enough attention.
