Room temperature....
Junkman
Northeastern CT
My wife is complaining that I keep the house too cold. I say that it is warm enough for me and the dogs, and that she should just put on another sweater. What temperature do you keep you home during the daytime, and at the nighttime???? She is claiming that the colder it gets, the more that her ***** stick out. As you can see, there is no truth to this. Up till last week, she was virtually flat chested!!! :lol_hitti
PS... any suggestions on what to get her for presents???
bmwpower
60-61 at night
63 in the daytime
A breast reduction might be a place to start.
Or find yourself a better job so she doesn't have to strip at night.
:lol_hitti
ironroad 9c1
Gum spring,VA
lol
I find its warm here at 71 when I come in from outside, but then after I'm inside for a bit I feel cold so I bump it up to 73 and I have a space heater on tin the computer room right now.I hate winter.
D KRAGER
Central IL
I think also depends on how tight your house is... Ours is nearly new, and when it's set at 67, it feels 10X warmer than my buddy's house that is 72, but his is an old farm house with little insulation. You can almost feel the wind blow through it.
krooser
Waupaca, Wisconsin
Since I bought a pellet stove I keep the house about 75F... we used to freeze @ 65 but not anymore... AND it's now cheaper to stay warm than when we froze.
Last month's gas bill was $30.00 for hot water...
walrus
Maine
R-54 ceiling and R42 walls, makes for comfortable living space. I leave my thermostat at 70 all the time. Use my wood stove to supplement
walrus
Maine
What did you do to get R42 walls?
2 by 6 walls, cut and fit foam, foamed cracks, 1 inch of foam over the inside face of the studs, thats 6.5 inches of foam, 7 per inch figures to 42 or so.
brad d
Winnipeg
wow that should not take much to heat, too bad that foam is so pricey
walrus
Maine
You buy insulation once, you pay for heat the rest of your life:)
I'm going to build a shop this spring( at least start it). I plan on covering the studs with 2" foam on the outside and then put on the sheathing. The theorey is in cold weather climes that any inside air escaping into your wall will never go thru dew point with R-10 or greater foam on the outside. I will then fill cavity between studs with fiberglas. I will do the underneath of the trusses with 2 inch foam also and then put r-30 or greater fiber above the foam. The foam makes a great vapor barrier if you pay attention to the cracks with canned foam or caulk. When you live in Maine, the winters are long and being cold *****:bounce:
Here's a link that goes over insulation methods by a guy who knows
www.buildingscience.com
Ironcrow
Arizona
Do you guys run at 62 to 65 F because you are comfortable at that temperature or just cheap bastrds? (if you have been looking for work for 6 months, disregard this question :))
J
Junkman
Northeastern CT
I did this when I built my home in 1982, and if I had to do over again, I would put the foam on the inside, not the outside. One thing that I have found in one place is that the mice have chewed a hole into the foam at the bottom, under the siding, and have made a tunnel to get into the walls. I have sealed it up, and I think that I have stopped the problem, but there is no way that I would make this mistake again. Learn from my experiances...
I keep the thermostate set at 55 when we go to sleep, and move it up to 62 for the daytime. The pellet stove keeps the downstairs at 70+. I haven't worked a day in the past 8 years, but I have been a cheap ******* all my life. :lol_hitti
chaingang
B'ville Ga
Holy **** Junk,
What do you mean "there are no good days with my wife". I could have a very good day with your wife. :lol_hitti
walrus
Maine
I've heard of this, I plan to use a piece of pressure treated on the bottom of the insulation and then use pressure treated plywood on the bottom course of sheathing. I have it on the inside of my house and it would easier if it was on inside so I may change my mind. Lord knows there enough freakin mice around me, thanks for tip
buzz
Winnipeg, MB
I just finished building and went the 2" foam route over a 2x4 wall with R14 in it. Foundation got 4" all the way down. I have also installed temp, RH and moisture content sensors throughout the wall section to keep an eye on things. The 2" is borderline for keeping the dew point out as there's a few points where the actual temp comes awfully close to the dew point temp. I would think that with a 2x6 wall you might actually see the dew point happen in the wall, unless you went to a 3" foam. Keep in mind, the temps we see here in Winnipeg drop down to -40.
As for the foam on the inside or outside, I'd prefer to have it on the outside to protect the structure from the massive temp cycling we see, not just to help with heat loss. I also sheeted the ground level with a sheet of pressure treated plywood that is half below grade and half above so the foam was protected down a ways below grade.
matt60j
MICHIGAN
Thats what 63 degrees looks like there:thumbup: My wife would never go for that. We keep it 69-70 during the day and 67 at night. We have a 1600 sq ft, two story berm house. We've used between 350-400 gal lp year for the last 5 years we lived here. All appliances are elec. -MATT
