I think Chuck's on to it now, the safest way to power that hour meter is to pull a 120v ckt from the panel with your feed wires. Then run it through the NO contacts on the auxillary contact block. That is, assuming you are going to pipe it. In which case be sure to flex from the disconnect to the compressor, or you'll rattle everything apart.
I am using flex already like you have suggested. Thanks for your input.
Search fleebay for REDINGTON-722-0004-Hour-Meter-AC-Quartz/ since the link did not work.
Where exactly from the following pictures do I wire the hour meter to? I am not an electrician as you can tell but can follow directions quite well.
[/URL][/IMG]![]()
As far as I can see you have no HOA switch so if you shut off your "service disconnect " which if your panel is 10' away and in sight your disconnect you put is useless and redundant. So if you shut it off then your compressor leaks air out when you turn it on it will power up the whole setup under full load which it is not designed for. In which case the breaker will wear out and fail eventually
regardless if its a switch or breaker it doesn't need to be there and is not ment to switch a motor under load thats what the starter is forActually the 'service disconnect' pictured is a switch and not a breaker. I have the same one.
Switch info
lg
no neat sig line
But to each there own if you want to wear a belt with suspenders that's fine
Jay! Where would you put the HOA?
You could put it anywhere they make small inclosures to put them in or you could put it on the side of the starter inclosures
You could also just use a switch to inturupt the control wire and use that to "shut down your compressor
jayrush, a question about interrupting that control wire. This is what I want to do to control a compressor installed in a small attached room on the outside of my shop. I want to turn it off as I leave the shop, and don't want to use the breaker to do so. It is not convenient to get to, and it is not meant to be a daily use switch. I want a switch by the door so it will be convenient and easy to remember to do as I leave the shop. Can that wire be extended away from, and out of sight of the compressor, without any additional circuit protection?
Sorry for the hi-jack, but the answer could help the op, as well as others.
jp
At present the control wire is about 12" of extension cord between the starter box and the pressure switch. Can that be replaced with wire in conduit to a remote on/off switch, using only the 40A two pole breaker that protects the compressor wiring to protect that switch loop? Or would it require a fuse or inline breaker sized to protect 12 or 14 gauge wire?
