shawn84&92
I have a pole barn with double bubble insulation between the metal and the perlins. I have built 2x4 walls even with the posts and plan to insulate and sheet the walls with osb.
Today, I got a great deal on unfaced r-11 insulation 7ft wide and 100 ft long for $30 per roll. My question is since I have double bubble is it okay to use the unfaced insulation or do I need to put a vapor barrier between the osb and the unfaced insulation? If I need a vapor barrier, what do I need to use. I plan to sandwich the insulation between the osb and the 2x4's.
Thanks,
Shawn
Thanks,
Shawn
