Workbench question
RH2
Hi all,
After seeing all of the great work here, I plan on getting 2 HF 44" cabinets, bolting them together, and then putting a workbench top on them. I will probably get a 16 gauge cold rolled steel top fitted if it isn't cost prohibitive.
Now for my question...should I do each top separately and have a seam or have it contiguous? Will a seam be annoying? I like the idea of going separate because I would have flexibility down the road to split them up and use them as work stations again.
I'm just a homeowner and these will see very light duty use.
Thanks,
Robert
marty_p
SE LoUiSiAna
Welcome to TGJ, Robert!
If you don't forsee moving the bench around, aim for one complete top. And if it will definitely be stationary, consider a toe kick beneath the boxes - as in a raised base to set them if you remove the casters. Your back will thank me later!
Also, check out the HUGE, 45+ page "Let's see your Workbench" thread here for lots of ideas:
http://garagejournal.com/forum/showthread.php?t=464&highlight=let's+workbench
And here is a stationary setup you may like:
http://www.garagejournal.com/forum/showthread.php?t=201182
Keep us pic people happy when your project materializes, and good luck in the meantime! :thumbup:
Thumper68
Duluth MN
I would do a one piece top, you can always cut it in half later. If you go this route get the top 8 or 10 inches longer, so the if you do split them then you will still have a over hang on each side.
48windsor
Olympia ,Wa.
I agree with the others make it one piece or the seam will drive you nuts. I myself bought a 6ft shelf just to cut in half and used a quarter inch steel for a top . I do a little welding and can ground the bench and weld anywhere on top . Its really been nice.
DIC
I would say one piece.. separate probably wouldn't line up just right and bug me
I fabricated two steel benches that **** together. One of the two benches is specifically designed as a welding table and is portable around the garage. The second bench is a copy but has a tool box and a solid top without fixture slots.
I prefer the flexibility of both benches being portable and having two styles of benches. They **** together exactly. I also have adjustable height wheels.
I have a third bench I built many years ago and I modified it to **** against these two. Having modular bench sections also allows you to place equipment between the benches as well, like a floor mounted drill press, welder, etc.
John in OH
SE Ohio & Eastern Virginia
Make it in one piece for now. If you ever want separate work stations you can always cut the top in half.
+1 on the previous suggestions for some overlap for clamping, toe-kick space, and maybe a knee-hole space if you want to sit and work on something.
R
RH2
Thanks for the welcome and all of the great info! Great pictures! I'm going to follow the advice given and go with one piece. If I ever do want to change, I can worry about it then.
Thanks! I can't wait to poke around here some more.
Thanks,
Robert
marty_p
SE LoUiSiAna
Just safeguard your wallet, credit/debit cards, and all liquid investments until the 'I need that' urge passes! :lol_hitti
Good luck, and remember to hit us back with pics!
