New here and I've read some of the threads on this issue but still unclear. Here is my situation, I’m trying to run 240 volts to a detached shop/garage about 100’ away. I would like at least a 100 amp sub panel with more than 6 circuits. I have a 200 amp service back of home and have space for a 100 amp circuit breaker. My question is if I use #2 copper THHN can I install 100 amp circuit breaker at the main and use a 125 amp sub panel with a 125 amp main breaker. From what I understand is the #2 feeder circuit would be protected by 100 amp breaker and the 125 amp would only serve as a main disconnect for the shop. Also thought about using 2-2-2-4 SER aluminum conductors but with a 90 amp breaker at the main and 125 main sub panel. But that is out the window as I read that 2-2-2-4 SER cable cannot be installed in conduit below ground, is that true? Any other suggestions?
Thanks
Thanks
