dc759ka PROBLEMS WITH CHUCK
mrbreezeet1
Moundsville, WV, 15 miles South Of Wheeling WV
De walt 18 V drill. This is the one Ace hardware had for $99.99 after $20.00 rebate in june 2010.
Really never used this drill very much, but the chuck is giving me problems.
It is noisy when tightening and seems to slip a lot, and not hold well.
Can these things be taken apart and fixed at all?
It don't seem worth it to replace,as I think a new one is around $50.00.
jeffmoss26
Cleveland, Ohio
I had similar problems with my DC720KA. Replaced the chuck but the issue did not go away. I ended up just purchasing a new DCD755KL hammerdrill kit and will only use the old one for hex screwdriver bits.
mrbreezeet1
fatielajia
You pay good money for something, and it is not worth a damm.thank you
0U2hFr
mrbreezeet1
So I guess I'm gonna just get another chuck.
I got the LH screw out of the bottom of the chuck, and did the thing where they tell you to put a 3/8" allan wrench in the chuck and hit the long part with a hammer.
Well it wasn't coming, so I got the idea to chuck a 3/8" allan bit that you drive with a 3/8" drive ratchet. I chucked the bit up real tight, even cranked it down with slip joint pliers,
And then put my 3/8 impact to it. Blew it right off.
thecanman
Lancaster, Pa
If you go with a new drill get one with a metal chuck. Those plastic chucks on the cheaper drills are junk. I have a dcd790 20v brushless drill and I love it.
Holt
Bellevue, Nebraska
I have the same one as you. Same issue. I went through multible drills.( company provided) eventually purchased my own milwaukee m12 drill and have never had a issue
RCStocker
Indiana, California, Australia
First of all you bought a De walt. They are over price and not all that good. I will not use them in my construction business. The quality just is not there.
Buy a good Jacob's chuck. There are German ones but they cost a whole lot more. Jacob makes great chucks. You should find one for about $30. I have a box full of extra chucks and I would give you one but I am moving back to my farm in Indiana and they are either there or in the cargo container ready to ship.
They are not hard to find but if you don't buy a Jacob's chuck you will be sorry. Once you have used them you will never change.
mrbreezeet1
I did not know De walt was no good. I always assumed they were a good name.
So what is the best drill to get?
I was thinking of this chuck
http://www.amazon.com/dp/B000WEIJFW/?tag=atomicindus08-20
mrbreezeet1
I offered $17.50 on this one, This is a 31403 but I think this might be a double sleeve, and I need a single sleeve?
http://www.ebay.com/itm/370904964731?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
I made the offer before I knew about the single/double sleeve.
Or is this a better chuck than the one I linked to above.
It would be about $24.00 with shipping if he accepts it.
There are so many choices, it is confusing, but of course, if it's a decent one, the cheaper the better.
The one I linked to above, the 31048, you can get for about $15.00.
I have a bid on one of those, hope it's a decent one if I win it.
jeffmoss26
Cleveland, Ohio
YEP that's it...rcstocker has spoken...dewalt is junk.
kossuth
Agreed. The quality was there a time ago and their older stuff was pretty good. I have an older 18 volt drill (one of the originals) and that thing is damned near indestructible, but the newer units are built much much cheaper. I have to get around to replacing the trigger on mine (burned it out drilling out 4x4 posts) but again the quality isn't there like it used to be.
kossuth
were they decent say 10 years ago?
I have a d walt XRP series 12 volt, but the batteries are junk, don't know if it would be worth getting batteries for it.
I would say that's about the time things started going downhill. As for the batteries being junk, all NiMH or NiCD batteries develop a "memory" of sorts and draining them down too quickly or over drawing on them will shorten their lifetime exponentially. Good news is you can actually have them rebuilt, vs buying new. I bought new packs when the time came for mine (I got them on a killer father's day sale for like $80 for a pair) but new packs rarely are that cheap.
Never used these guys but that is what they do for a living, but it looks like they also sell new batteries too.
http://www.voltmanbatteries.com/servlet/StoreFront
And here is some reviews I found of them online.
http://lumberjocks.com/reviews/2740
Obviously do some more research, and there are most likely other outfits out there that do the samething. You could buy the cells and try to solder and redo the packs yourself (You can damage cells so you gotta be good at it). Either way if you like the tool but have grown to hate the battery life and don't mind spending a few bucks rebuilding the packs then this isn't out of the question.
As far as tool life and usage on a battery goes voltage means squat. You want to know what the battery is rated for in Amp Hours. This is a little known fact that nobody really publishes. Think of it this way in layman's terms. Voltage is how fast something can run (aka sprint). So a 20 volt battery can really twist the snot out of something, but it means nothing if it can't run for more than 30 seconds. Your Amperage dictates how long it can run (marathon runner). So this basically dictates how long the tool runs during your building project and how often you have to swap out packs. Your amp hour rating is really what you care about TBH.
mrbreezeet1
Thanks, as a matter of fact, someone borrowed that 12V drill, and it had a burning smell since then. (when running) I don't know what that would be.
I'll tell you, those batteries never did seem to be that good.
Did not seem to hold a charge, or seem to last like they should have.
kossuth
Sounds like they burned the brushes drilling something on too high a speed or with too much pressure. Brushes are only like $8 for that drill so no sweat there.
mrbreezeet1
This HI-CAPACITY REBUILD - ANY BRAND sounds good, but damm, it's $80.00 per battery.
wonder if it would pay me to try to rebuild them myself?
Is there 6 batteries in a 12v battery pac.
I will watch the video.
$50.00 each for the standard, thats not bad.
