I am not looking for HO ballasts.
Got my light fixtures from contractorlighting.com. They have the 32w t8's for a fair price and ship them to your door. Service is good, had a bad one and they shipped out a new one the next day. I do not work for these guys, just a good place to check.
Here's the link:
http://www.contractorlighting.com/4ft-lamp-watt-fluorescent-double-channel-strip-120277-p-400.html
If you go to the link provided, there is a spec sheet that listed it as "Phillips Advance ICN-4P32-SC “NEMA Premium Electronic Ballast “. Hope thats what you needed![]()
FWIW - I have 14 of the "cheap" 8' 4 bulb Lithonia fixtures from HD - $40 a pop. In three years, I've had one bulb fail.
What height cieling and any FM reception problems?
I called the place to ask them specifcally which ballast they use. He said the current batch of 4 light, T-8, 8 footers uses a GE 432MV-N, 74463 (he also said they sometimes get an "advance", which I assume means the phillips one you stated).
I asked if it was a residential ballast and he (Chris Petty) said he has never heard of a residential ballast or it being different than a commercial one.
I explained to him there had been many complaints of commercial ballasts knocking out FM reception. He said it was due to crappy chinese ballasts and maintained there is no such thing as a residential ballast.
I asked him if possibly they used a high enough quality ballast that it did not matter if it was res or commerc, and hence why he had never heard of the difference, but he did not know.
So I guess I'm back to square one if I really want residential ballasts. Until I read that 5 page thread on FM reception, I didn't care either way.![]()
Sorry for the threadjack............
Curious why you asked this? I was going to post a thread about the same thing.
I have T8's in my garage with 12' ceilings and during the day with the lights off my receiver gets a great reception, but come night time when I turn the lights on the reception is terrible. I can stand by the switch and turn the lights on and off and hear the radio go from clear to fuzz. I got what I thought was a damn good antenna for my receiver but it didn't make any difference.
These are the fixtures I have....
http://www.homedepot.com/p/Lithonia...ture-IB-632-MVH/202193185?N=c7bu#.UpOfBW3yUjo
so still no concrete location to get this then?
Ooops! That's the first big red flag. There most definitely IS a difference. And here he has gone deep into CYA/BTWBS (Cover Your A__ / Baffle Them With B---S---) mode. Typical salescritter.
There is potentially another way to skin this cat. You can add in-line filters to the circuits feeding the fluorescent lights, which will go a long way toward reducing the emitted EMI/RFI. They're often not 100% effective, but they usually don't need to be; you only need to reduce the interference ENOUGH that the receiver can "capture" the desired signal vs. the undesired one (which generally requires the "desired" signal to be about 1.0-2.0 dB stronger at the receiver's input, assuming a decent-quality tuner).
An inline filter (can you even buy those for residential applications?) will not help with this problem. The ballast is the cause of the interference - not the device suffering from the interference.
FWIW: Installed 9 x 4lamp T8 Sylvania Commercial grade fixtures in my shop 2 years ago. No notable effect on FM reception or wireless network signal.
The inline filter works both ways... It filters what the device gets and reduces what a device can transmit out the power line.
Yes, I could see that. But the issue here is FM signal interference not EMI on the line itself.
What are some common sources of radiated interference?
The most common offender in the radiation of EMI is the electrical power cord of the electronic device itself. Since the powercord can act as an antenna, conducted EMI can also become radiated interference.
External EMI filters can be installed on the line side of an electronic ballast to limit
unwanted conducted EMI from entering the building wiring. Additionally, a fixture can be
designed with a grid lens or grounding cage to cover the lamp chamber in order to increase the
impedance to a specific frequency and to bring radiated EMI to ground. Although ballasts do not
have to meet FCC standards for radiated EMI, this type of EMI still presents a practical issue and
fixture manufacturers must account for it. Because high frequency EMI has a very short
wavelength, it can escape fixtures through very small openings, making high quality fixture
design important
EMI that will swamp an FM signal can easily be transmitted on the power line. I think your point is that it could be from the frequency of the lamps...
What is the reasoning for that and is there any fix besides replacing the ballasts?
--Joe
Where exactly is this "damn good antenna" located? And exactly what type is it? If it is one of those "magic" (yes, I'm being sarcastic) amplified indoor antennas popularized by such outfits as Terk, it is near-certainly doing more harm than good.
Your GJ profile says you're in "SE Michigan"; I'm guessing that means somewhere in the greater Detroit / Ann Arbor / Toledo area. If that guess is correct, inadequate signal strength from the broadcast station is very likely the LEAST of your issues. Your problem is that you ALSO have a strong local source of interference signals (i.e., the lights/ballasts). What you need (besides either better ballasts and/or EMI/RFI filters on their power feeds) is a high-quality PASSIVE antenna, located as far away from the interference source(s) as possible. If this is a directional antenna, aimed to put the interference source(s) into one of the nulls of the polar pattern, so much the better. Either way, the other thing you need is to shield the utter He__ out of the transmission line between that antenna and the tuner's input; a good-quality quad-shield RG-6/U cable would likely be your best bet here.
I would be utterly amazed if those had Residential-appropriate ballasts in them.
Could anyone point me in the direction of where I could look at purchasing residential ballasts? The fixtures I have have 2 ballasts per fixture so I have 16 ballasts in the 8 fixtures. How do I know what ballast to buy anyway, do I just match the specs on the one I have to a similar spec'ed one that is rated for residential use?
--Joe
My gut reaction is to seriously doubt that. I know that modern electronic ballasts run the lamps much faster than the traditional 120 Hz; but are they really up into the multi-MHz range? A few dozen kHz, I could easily imagine; and with a strong enough harmonic structure, you MIGHT get up into the range (400-500 kHz) where AM tuners would be affected. But even the IF frequency in an FM tuner is up at 10.7 MHz, let alone the carriers at 88-108 MHz.
I can not use an FM radio. AM is fine. FM is so full of interference it is not pleasant to listen to, if you can make it out at all. The two T8 are switched separate from the four T8's, and it is almost tolerable with only two on, and out of the question with all six, or even four.
This is similar to the passive antenna that I have......
http://www.radioshack.com/product/i...ce=CAT&znt_medium=RSCOM&znt_content=CT2032189
It is located across the back wall of my garage above the receiver......figure maybe 8' below the ceiling.
Can anyone recommend me a quality 2 lamp 32w t8 fixture and ballast combo? I have some from lithonia lighting and they are cheap on both counts. I am not looking for HO ballasts and am looking for wire in fixtures with exposed 4' tubes.
I grabbed one of the GE residential ballasts the other day while @ HD.
Says right on the front Residential Electronic Ballast, and Grade B.
Open it up and it comes with this paperwork that says Commercial use only, Class A
ARRRRG...............
The ballast is fine... Wrong paperwork with it.
But either way, it's mislabeled. With regard to EMI/RFI from misc. devices, the pertinent section of the FCC regulations is 47 CFR Part 15 (cf. http://en.wikipedia.org/wiki/Title_47_CFR_Part_15 and http://www.ecfr.gov/cgi-bin/retrieveECFR?gp=&r=PART&n=47y1.0.1.1.16). Further, Part 18 (which deals specifically with industrial, scientific, and medical equipment) does not even include any reference to "Class A" vs. "Class B" equipment (cf. http://www.ecfr.gov/cgi-bin/text-idx?c=ecfr;rgn=div5;view=text;node=47:1.0.1.1.18;idno=47;cc=ecfr).
Labels with cert marks are really tightly controlled, no way that's a typo and you would think that big companies like GE and UL would know what subsection to list.
Even worse, other ballast manufactures have the same mistake!!!![]()
Or....
http://www.tscm.com/FCC47CFRpart18.pdf
Page 719 lists RF lighting devices "FCC Part 18, Subpart C".
The products I work with use the same standard, its a fun read.
On your link to the section 18 regulations search for the term "lighting".
I don't think it was a "mistake", per se; I think they're talking about something else, and/or engaging in a bit of corporate CYA.
Interesting. Given that the scope of Part 18, as established in §18.101, is explicitly limited to "industrial, scientific, and medical equipment..." (a category of devices which I would not normally consider a run-of-the-mill light fixture to be a part of), and the term "RF lighting" is never actually defined within the statute (AND the word "lighting" is NEVER otherwise used except as part of the undefined term "RF lighting"), they've created sufficient ambiguity to keep lawyers arguing over it (at OUR expense) for decades to come.
Yep... Typical Washington, DC.
What I have found is that there are the rules and then there is the application of them. I read them, and then talk to the engineers at the NRTL i'm working with
to see if I am interpreting them correctly.
My experience is that you need to be working in the field for a while to understand how and what to apply where. I went through this on several details of my project. The project engineer would explain why he felt a particular rule applied to my device. If I did not like his interpretation, I could provide a counter point and try and persuade him or find another lab and see if they agreed with me.
In this case, its not the into in the scope that determines the device, its why its generated that matters.
Part 15 is for unintended generators: "Unintentional radiators are devices that internally generate RF energy to perform their intended function. In so doing, they may accidentally radiate unwanted RF signals."
Part 18 covers intended generators. "This category of commercial products also purposefully generates RF energy to perform an intended function. In operation, this equipment may accidentally radiate RF energy. Examples of products in this category include, RF lighting devices, medical diathermy equipment, and cooking devices (e.g., microwave ovens) that generate heat by induction. "
If you read 18.107 part C, it includes equipment designed to generate and use locally RF energy,
they include domestic usage.
18.107 Part G includes equipment for use by the general public.
(g) Consumer ISM equipment. A category of ISM equipment used or intended to be used by the general public in a residential environment, notwithstanding use in other areas. Examples are domestic microwave ovens, jewelry cleaners for home use, ultrasonic humidifiers.
(c) Industrial, scientific, and medical (ISM) equipment. Equipment or appliances designed to generate and use locally RF energy for industrial, scientific, medical, domestic or similar purposes, excluding applications in the field of telecommunication. Typical ISM applications are the production of physical, biological, or chemical effects such as heating, ionization of gases, mechanical vibrations, hair removal and acceleration of charged particles.
Fluorescent lights with electronic ballasts, electronic ballasts and CFLs typically
operate under Part 18.
