Are there non-metal wheels/rollers replacements or jacks?
FleaDog
I've got a heavy long reach HF 2.5 or 3 ton low profile jack, works well, only issue is I tuck it in under my workbench and when I take it in/out the large front roller/caster, and the other caster wheels intermittently roll/stop/roll etc as I am moving it about and it scratches/gouges my epoxy floor. So is there something I can replace these things with like a hard rubber or urethane or something? Thx.
nicksnothereman
In the Mojave
I've got a HF low profile jack, works well, only issue is I tuck it in under my workbench and when I take it in/out the large front roller/caster, and the other caster wheels like to intermittently roll as I oil it in/outand scratch/gouge my epoxy floor. So is there something I can replace these things with like a hard rubber or something? Thx.
Put a thick piece of non-painted cardboard (from a box) underneath it (long enough that the jack doesn't move off the cardboard. You really don't want to put wheels with a material that is softer on a jack...no friggin way.
That's what I do at home. It's not the weight not the wheels that are causing the damage. Cardboard will at least put a layer between the wheels and the surface without causing failure (the wheels will bed into the cardboard). Don't reuse pieces of cardboard you use with a jack (jack stands=okay if you line it up correctly with the previous indentations).
Agreed, use a mat of some sort. if it's just for under the bench, then I see no reason not to re-use the cardboard..
zkling
Don't quote me on this, but IIRC, a high end Euro jack maker uses steel wheel, but they have a groove cut in them with what looks like an O ring. They advertise it as non marking for showroom floors.
Hold on, let me find a link. :beer:
Here we go.
http://www.ac-hydraulic.dk/en/products/hydraulic-jacks/dk20-dk20q/
Maybe if you have access to a lathe, you can chuck up the wheels and cut a few grooves for O rings and use that to protect the floor. :dunno:
zkling
DAMN, I thought I was going to beat you to it LOL. The orings compresses under load to the weight of the vehicle spreads out over the entire caster.
That is kinda what I was wondering. I would venture to guess they are pretty high durometer? Hence my suggestion of multiple groves across the face to spread out the load. IDK, I thought AC is pretty well respected for their products, so it has to work somewhat well. :dunno:
Have you used that jack before?
Burgerkong
Markham, Ontario, Canada
Nope, I'm still fuming at the local GJer who picked up one for $80 a few years back. I think I can find the thread.
Thumper68
Duluth MN
+ on the inner tubes, just cut a section a little wider than the steel wheel and stretch it over the wheel.
F
FleaDog
The inner tube idea sounds great and it sounds like it will give the wheels some traction so they will roll instead of sliding/scratching.
djb2
Redwood forests
It may be that the o-rings simply flatten under pressure, transferring almost all of the weight directly to the steel wheels. If that's the case, the groove needs to have at least the same cross-section area as the o-ring.
nicksnothereman
In the Mojave
OR……. Presto the wheels will break apart and the car comes crashing to the ground.
Should never work under a jack anyway bro.
I do agree with what you're saying though. Messing with a structural part of a device intended to lift a lot of weight is a friggin darwin award in the making.
