Need new 60 gallon compressor
jack bacon
Loretto, MN
My son is moving into his new house and taking his compressor with so now I have to buy a new compressor. I would prefer a 60 gallon and would love a Quincy but don't now if it is in the budget. Any recommendations on a 60 gallon compressor in the $500-600 range. Would be using it for air tools, blast cabinet, etc. Would like it to be as quiet as possible.
Thanks,
Jack
NHBandit
East Tennessee
I bought a Campbell Hausfeld 60 gallon on sale last year right around this time for just over $400 at Tractor Supply. It is pretty much the same compressor Home Depot and Lowes sell under their store brand names. I had the same one at my old shop in NH for around 6 years and when I sold that house I left it there and it was still working great. If it was me I'd just watch the specials and sales they all have this time of year and buy it from whoever has the best deal. Red, Black, Blue, Grey like mine, they are all pretty much the same other than the paint & the decals.
holdover
VA
I have two of the Husky HD 60 gal compressors. Bought the first one 4 yrs ago for about 429.00 and liked it, when they decided to change the color they put the red ones on sale for 329.00 and I bought another. Have them plumbed so I can run one or both. They are a good compressor for the money, have a good guarantee, put out a fair amt. of air @ 90lbs, and now I always have a back up if anything goes wrong with one
budco
FL
If your going to be using it a lot for blasting, I would get a two stage. Although if you go for the two stage you will be spending a lot more than the $500-600 range. I have a single and it works blasting but take a lot longer. As soon as I move and build a new shop a two stage is going in.
GarageWarrior
Westerly, RI
Two stage is higher pressure but lower cfm. For sandblasting at 40-60 PSI a single stage is better.
dmeadow
Houston, Texas
I bought a Puma 6060V from Northern Tool a few months ago. Got it for $400 on sale and with a coupon code. Last I saw it was on sale for $499 (reg. price $529).
At 3 hp single-stage it works great for just about everything, though I have to let it catch up every so often when using the media blaster.
I haven't owned a bunch of compressors so I can't tell you how quiet it is versus some of the others. However, according to my iPhone decibel meter it puts out about 87 decibels versus the 94 that my 20 gallon oilless Sanborn would put out. That may not sound like much difference, but in the world of decibel measuring, that's huge.
I bought the Puma because it got nothing but positive reviews and everyone was pleased with the sound level. The latter was important for me because I work in a garage attached to the house.
460Rustang
Nawlins
CL daily, picked up an 80 gl Kobalt with factory regulator and outlet *******,.....one hour's use for $500. :thumbup:
GarageWarrior
Westerly, RI
Both of those statements are just utterly incorrect. Well, except for the part about two stage producing higher pressure, that part is right.
Look at multi-cylinder pumps that give you options of parallel and multi-stage configuration: multi-stage is only recommended for output over 100 PSI. Under 100 PSI a single stage/parallel configuration is more efficient.
Compressing air to 160psi only to regulate it down to 40-60psi is wasting power. Twin cylinder air compressor running in parallel configuration will produces higher CFM than the same compressor with cylinders piped in a dual-stage configuration.
Zrexxer
Pflugerville, TX
Wow, you're on a roll. That old chestnut has been incorrectly parroted on internet forums since the beginning of cyber time. A receiver pressurized to 200 psi contains twice as much air as one pressurized to 100 psi, so how again is that air "wasted?"
chops101
S. FL
Keep checking CL. I see industrial units all the time, just be ready to grab.
I scored a new IR 2 stage, 60g, 0 hours for $450. (Well, he was asking $700)
Guy bought it for a new business that never opened.
As far as big compressors go, it is quiet. You can carry on a conversation without shouting with it running.
Ross/Kzoo
Richland Mi.
How did you hook this up electrically? Wire size and breaker size?
dmeadow
Houston, Texas
Must be a regional thing. I searched the Houston Craigslist for months for a reasonable deal on an industrial quality compressor. Mostly I saw Husky or Kobalt compressors for sale at so little discount from new it wasn't worth taking the risk on a used.
I saw a few 3 phase that just wouldn't work in a home setting, or some 80 gallon and horizontal ones that wouldn't fit where I wanted it. Was a waste of time for me.
Falcon67
Merkel, TX
The 60 G $400ish compressors - CH, Husky, etc - all seem to be about the same and work good IMHO for most things. I scored my CH for $400 at TSC. If you do a LOT of blasting, you'll want more air volume. If you do occasional work, have condensation controls and don't mind letting the compressor catch up once in a while, the smaller units will do the work. I painted two cars with a 1.5 HP 25 gallon single piston belt drive, so things way outside the norm can be done if you work at it - it's just not recommended.
GarageWarrior
Westerly, RI
You are right that you can store more air in the same volume at higher PSI.
But we are talking about continuous output as needed for sand-blaster, not buffering for an intermittent tool.
At lower PSI single stage is more efficient. As I said earlier, don't take my word for it, compare compressors with same HP from same manufacturer that offer them in a 2 stage and a single stage configurations:
5hp Jenny Compressor with two stage pump: 15.5 CFM @ 100PSI
5hp Jenny Compressor with single stage pump: 18.3 CFM @ 100PSI
http://www.jennyproductsinc.com/portables/tswp.html
http://www.jennyproductsinc.com/portables/sswp.html
Single Stage and Two Stage Reciprocating Pumps
Reciprocating (Piston) Compressors can be widely found in two primary configurations; Single Stage and Two Stage.
Single stage air compressors work by drawing air in and subsequently compressing the air to its final pressure in single piston stroke. Single stage air compressors can attain pressures of up to 150 PSI. Typically, a single stage pump will have a higher CFM(Cubic Feet per Minute) rating than a two stage pump because every cylinder is drawing in air and compressing it with air during every rotation.
Two stage air compressors work in a very similar manner with the primary difference being that they compress the air in 2 steps or stages. During the first step or stage, air is drawn in and compressed to an intermediate pressure. After being compressed in the first stage, the air is piped, usually through an intercooler where the air is allowed to cool, to be compressed in the final or second stage. Two stage compressors are normally good for pressures up to 200psi. Two stage pumps are more efficient at higher pressures because the air is cooled between the stages.
http://www.jennyproductsinc.com/howtochoose.html
You misunderstand if you think more stages is always better. It depends on output PSI.
Ross/Kzoo
Richland Mi.
If you're willing to travel a little you could try "One Craigslist"
http://www.onecraigs.com/craigslist...rl=www.onecraigs.com/&ref=&ss=7402j2875222j22
01ss
My husky has run flawlessly since I bought it with regular weekend use. If its hot and I'm working it hard I will put an extra fan on it to help it stay cool.
chops101
S. FL
10-3 solid, short run of it (~20') 40A breaker in the panel.
I use a 50A breaker in a very small service box mounted on the compressor to switch it on/off.
Spudland_Dave
Maine
That's what I have as well, its a great compressor for the money. Quiet, works as advertised. No problems thus far.
tlmartin84
West Virginia
Kobalt 60 gallon rated for 11.5 cfm and 3.7 HP
It is a good compressor, not to noisy. I went to a larger pulley on my motor to speed it up.
It does everything I need except blasting. I have to blast and wait, blast and wait. I'd go with something around 18cfm or larger if I was doing any kind of blasting.
It also runs alot when using my cutoff tool. Must be an airhog.........
460Rustang
Nawlins
PaulR
Hadley MA
BTT. Hello everyone, haven't been around much in the past year or two, been real busy with other stuff besides the garage.
Anyways:
I'm looking to upgrade from my 30 gallon Husky to this Quincy 60 gal:
http://www.northerntool.com/shop/tools/product_200350475_200350475
I've got the money and the 220 (honey), is there any reason I should NOT buy this Quincy?
Edit: I'll be doing 2-3 frame off Jeep restorations. Lots of sanding/grinding.
Travinsky
Miami
Must be a regional thing. I saw a few 3 phase that just wouldn't work in a home setting, or some 80 gallon and horizontal ones that wouldn't fit where I wanted it. Was a waste of time for me.
Same here and quite frankly many people have been robbed and shot doing cash deals. So I might save $500 on a 2-stage, but...
PaulR
Hadley MA
Yea same price there as Northern. Had success through Northern in the past, no complaints. I went ahead and ordered it the other day (could not wait around for y'all to reply!)
I hope that my three little girls will inherit a nice compressor now. I'm most worried about transporting it from this commercial addy where I'm having shipped to my home down the road, and getting it into place. I think its actually heavier than my 24 gun safe, heh.
Edit: Northern does say it was "shipped" as of yesterday, but no tracking info available. Which I know is a crock, I won't see it until some time next week. I wish they would keep large shipments like this accurate and contact you so you know when they are coming.
Truman Sparks
Florida
Most of the CL ads in my area were also for used equipment with new/retail asking prices.
I eventually went with the Kobalt (Campbell Hausfeld) from Lowes for $499, less the military discount.
Dan in Pasadena
Pasadena, CA
I bought a used, but clean working 60 gallon Harbor Freight single stage for $265.
I thought it was agreat deal and I guess I still do!
Streetbu
Central NY
I bought mine at Tractor supply. Looked for the one with the highest CFM @ 90psi, this model was it. Much higher than most single stage 13.5cfm@90psi Was $549 IIRC and used my buddies farm account to boot :D Notice it's a 3 cylinder, not the normal 2. Whatever you get, make sure to follow the directions for start up. Most want you to leave the main output wide open so it can't build pressure and run it for 30 minutes then change the oil again.
rodm1
Personally I would rather buy a used industrial model in that price range then any new one. Just plan on rebuilding it someday if you have to.
Travinsky
Miami
Is there any reason to buy the Lowes vs the Home Depot version of CH? Warranty, location, color, etc?
markag
Metamora, IL
The Kobalt and husky compressors are actually Sanborn compressors, not CH. The CH compressor at tractor supply has lower ratings than the other ones, and if you compare, you will find that they don't have quite the sane configuration in the motor and pump. I bought the Sanborn one from Menards. It is the sane as the one from lowes or Home Depot, but it was about $50 cheaper.
Sent from my Galaxy Note 3 using Tapatalk
Truman Sparks
Florida
The home improvement stores have varied their suppliers over time. The current Kobalt is a CH, and the current Husky is made by MAT Industries (MAT also makes similar 60 gal compressors wearing Powermate, Industrial Air, Sanborn, and other labels).
I believe that the 60 gal Kobalt used to be a MAT, and the Husky used to be a CH. It'll probably change again one of these days.
gearhead1
NC
I've had my Campbell Hausfeld for 15 years now. I change oil in it every other year and clean the air filter. It's still going strong.
