LED work light recommendations
fourjeepin
Atlanta, GA
I have an older dual halogen work light that really puts out the light (and heat) but the bulbs blow so quickly and the energy efficiency of LEDs would be great. Anybody have one they would recommend?
This old Craftsman light is what I am looking to replace.
Provincial
Near Salem, OR
If you get a LED light, keep the old halogen for when it is cold in the garage. I find the halogen lights double as radiant heaters that make working in the cold possible. In warm weather the heat is a big negative.
If you only use it in the cold the bulbs will last a little longer and you won't be using it enough to burn out very many!
Bigplum
Cotswolds England
Just look for R7S led on eBay , that's for the 118mm long halogen lamp
Here's a item number 330970077065. But there's loads on eBay ,
I can't tell from the picture if your lamp takes the longer or shorter lamp but both are available
