what are composite ratchets?
sloppy
not metal. so no sparky and not as cold maybe lighter in weight to..
mech-tech
Cheap fine tooth ratchets with big handles that are covered in a rubber coating. They are popular at harbor freight, along with the tekton brand and other off brands from auto parts stores. They hold up well, especially for the price. I love my little 1/4" ones I got from amazon, but again, the handle is a bit large for a 1/4" ratchet.
monomach
Illinois
Plastic around a metal core.
Benefits:
-Nice for working around things you don't want to bang a piece of metal against, like paint.
-Better grip.
-Comfortable to use for extended periods of time.
-No sparks if you're working in a cloud of flammable gas like a *****.
-Don't freeze your hand in winter.
-No rust.
-Lighter weight.
Drawbacks:
-They're suitable for some surprisingly heavy use, but I sure wouldn't go using a cheater bar on one because the metal core of the handle is a little thinner than a normal ratchet handle.
-Not available in a long handle for the obvious reason.
-Not available in a flex or roto head.
-Harder to keep clean. This is more a problem for the tool polishers out there,
Speaking about the Harbor Freight versions in particular, with how little they cost, there's no reason not to own them. They're pretty nice.
Davefr
OR
okay would you recommend one?
Absolutely. I generally stay away from HF but these ratchets are a real gem. Once you start to use one you may find that they become your go to ratchet for ordinary tasks.
These ratchets and their cheap mechanics gloves are a couple of the items actually worth buying.
I have yet to see any threads about how these ratchets have failed in normal use.
Aberdale
+1. I like these HF ratchets better than anything else in my box, including SO.
I've actually used them on every tough or rusted bolt that I would use a steel ratchet, and they have held up well. They're ratchet mechanism is as smooth as any. And if I do break it, I can afford to buy another one.
'dale
JimDon
Living in Northern Wisconsin, I end up doing a lot of winter work. It is brutal when you are in -20 weather with a wind chill making it feel like -90. When I'm out like that, the only ratchet I want in my paw is that HF composite. Have all three sizes and they are much easier to hold onto when it is that cold. Lube them up with some Superlube or even a lightweight oil, and you will hardly hear the ratchet mechanism work.
Have yet to break one, but like others said, if I break one, get a replacement free or just buy another since they are very very inexpensive.
Cheers,
Jim Don
TJay
Muskego, WI
I needed a 1/2" ratchet one day and HF was the closest place to me, stopped and grabbed one figuring idc if it breaks lol.
I liked it so much I grabbed the 3/8th afterwards. Now I just need to get down there and get the 1/4" since they were out at that time.
Have been using the 3/8 quite a bit over the last couple months and they have held up great, love it for working around anything energized lol
Brownsfan
Cleveland Ohio
I actually had the 3/8 slip/skip. I was really leaning into removing a bolt and it just gave out. I will admit I was really pulling hard on a seat belt bolt. When it gave I thought my head was going to go through the roof. Man that hurt. It was very comfortable to use.
Deskmechanic
Long Beach, CA
I use the 3/8 for working on motorcycles because if you slip it doesn't scratch. Also the offset handle gets your hand away from the surface without adding slop from an extension. Pretty much everything else I own is from the truck, but man I love those composite HF ratchets.
Big Pete
available in the UK from MachineMart
http://www.machinemart.co.uk/shop/product/details/pro134-38in-pro-ratchet-polypropylen
they also turn up at autojumble tool outfits from time to time in different colours.
Halfords also do one, but without the offset. The whole 1/4" drive set is about £15 and usually on sale around now, comes in a grey plastic box with a indowed lid. I love them, I think I have 4 now, mostly for motorcycle work.
sloppy
'dale
Or you could just go get another free one from HF they have a lifetime warranty..
neophyte
Pennsylvannia
There's a lot more to "non-sparking" safety requirements than simply being "non-metal." In a pinch most composite ratchets may be fine or at least better. Most non-sparking tools have to be manufactured from very specific materials, or materials treated in specific ways. Most non-sparking tools aren't steel and don't have steel parts unless those steel parts are specially treated or unexposed. Non sparking requirements may also require non-static materials.
My understanding was composite ratchets were more about making the ratchets lightweight, and more ergonomic. JimDon's comment about cold weather conditions also makes sense.
sloppy
something being insulated and something not sparking are different things.
Mohawk Dave
SoCal
I bought all 3. They are my go to. Love them.
Someone mentioned their gloves...I always wear Tillman deerskin/goatskin leather, but carry HF in all the vehicles. Also, I just started using their insulated winter gloves...PASS!!!! for 10 bucks.
Cobra5150
GA
The only thing I don't like about the HF comp ratchet is the reversing lever is backwards from the rest of my ratchets.
cheechi
Triad, NC
I like mine a lot. Even with plenty of other ratchets these are usually the ones I grab. The handles can be bulky if you're in a tight space but compared to an F80 for example not much more bulky.
mark5767
Minnesota
It's been below zero and snowing a lot around here recently. Composite ratchet very nice for working in the cold on the snowblower, like adjusting the skid plates just right!
marsh1
Texas
Bought one after seeing this thread. Been looking for a mid size 1/4" drive and so far I like it a lot.
TreePointer
PA
I bought a couple HF composites to use when working on batteries to prevent arcing and sparks from accidental shorting. Now I use them all the time in cold weather.
