Air compressor TANK question-
MatBirch
Filer, Idaho
Is there a check valve in the DRAIN bung? I know there is water in my new-to-me tank, I can hear it and feel it. I opened the petcock, and nothing. I pulled the petcock and nothing? It looks like there is metal covering the hole from the inside?? The petcock was clean, and operated fine. I want to put in an elbow, but at this point, it seems that maybe a special fitting is needed to depress a spring loaded valve???
Thanks
thebeekeeper1
Illinois
I let mine blow out under <some> pressure.
As above, you may have rust scale and crud blocking it. That's a sign of past neglect. Not good, but not necessarily fatal.
MatBirch
Filer, Idaho
This is definitely not crud or rust. It's silver and shiny. I poked at it, it doesn't move. Just gives me a very firm, dense, metal on metal feel with my screwdriver:dunno:
Does the petcock push up into a check valve when opened?
CNGsaves
KS and OK
Way too little information . . . . . what do you really have??
Pictures tell a thousand words.
:needpics:
MatBirch
Filer, Idaho
Thanks guys-
I took a couple of pics. It's hard to shine a light into a hole and take a picture...
larry_g
oregon
A bit out there but do you suppose that the bung was welded onto the outside of the tank without having the hole punched first? From all I know and seen that hole should be open. Can you ask the previous owner if he ever drained the tank?
lg
no neat sig line
Davefr
OR
Can you remove the bung and take a look inside? (probably easier said then done). My guess it's a chunk of scale or debris inside the tank that broke loose and is covering that hole.
Or maybe leftovers from sort of automatic drain retrofit.
Did the petcock look original when you removed it?
I'd be temped to drill it out and then clean up the threads with the appropriate size NPT tap. Whatever the mystery, you need the tank to drain.
MatBirch
Filer, Idaho
Thanks gang- I briefly tried to remove the hex fitting, but of course its ... Tight to say the least. I need to drain the oil out of the pump tonight anyway, so I'll be able to lay it the rest of the way over and get nasty with it.
Thanks-
ZRX61
Solar Blight Valley, SoCal
I have that exact same model of compressor. There shouldn't be anything blocking the drain.
I also fitted mine with an elbow, 6in brass ****** & a ball valve for easy access when draining it.
I'd be tempted to stick a punch in that hole & give it some percussive maintenance ;)
b-body-bob
Almost Heaven
I agree with you, get it to where it's accessible and have at it. I'd be careful to not smack it too hard at first though, think of your hand if you really lay into it and it pops right through on the first shot. :lol_hitti
MJB24
Minnesota
Can we get some more pics at different angles of sureshots avatar while we are at it as well.
Sureshot
Bridge Creek, OK
I wish I had some. I have had lots of requests but after copying that pic from I don't remember where to my desktop I resized it and deleted the original, and as luck would have I ran a disk cleaner so I don't have the original and my history was erased. I looked where I thought it came from but was likely a link on a link on a link time killer.
So for now she is all mine boys. Let me know if you find her.
MJB24
Minnesota
Well then. Back to the compressor tank. I might not quite hammer on it yet.
It might be better to drill it. Depending on if it can break up or not. It may just land back where it was and be harder to drill if it moves around.
MatBirch
Filer, Idaho
Well, I feel pretty silly, but I got it handled. I punched through with a slotted screwdriver, and once it started to go, I was able to twist and dig out the ****. Behind it was well over 2 gallons of water! It was very interesting though- the water was "layered" in the tank. The first thing out was brown, and just plain "dirty" looking. That was about 2 qts. Then it cleared up to almost totally clear for about 6qts. The last few qts were very rusty red brown with the milky oil residue at times. Those last few stained the heck out of my plastic paint mixing cup I was using to dump with. It was really ugly stuff!
Thanks for the help everyone!
thebeekeeper1
Illinois
If you know how old the tank is, and now know it has every drop of condensation it ever produced, I would be nervous regarding the tank's integrity.
All
Everything about your story is typical. The drain obstruction, the layered strata of water inside, the requirement to force the drain open beyond just twisting the petcock... everything.
What is worse, is when the tank drains are partially obstructed, allowing just enough water to seep out by gravity, or to blow out under pressure, to mislead one into thinking that their tank is drained, when it is not.
Very good that MatBirch pursued the matter. I encountered the same thing with an older air compressor I bought used.
G_P
Central CT
She is known as "Chicken Tuna Laura Harris"
http://cooldudestuff.com/2012/08/most-amazing-****-of-the-week-goes-to-ms-chickentuna/
And she is 44 BTW.
Reverse Google image search is your friend in these situations;):evil:
