snap on hard handles for 1/2 ratchets?
shockwave
Marietta,ga
I have been looking fir the part# for the hard handles for 1/2 drive ratchets. I have found them for 1/4 and 3/8 but know 1/2 stuff however I do see them on eBay all over the place,are these screwdriver handles converted to 1/2 drive ratchets any help would be helpful
I did not find anything while searching thru old threads
Subyroo651
Northern IL.
They have the new Hard Handles available now.
1/4" - THD72-12
3/8" -FHD80-12
1/2" -SHD80-12
Add a letter on the end if you want a color, the numbers above are for black.
CWP1616L
USA
Are those hard handle numbers direct replacements for ratchets that already had a hard handle?
In other words, those hard handle numbers are for ratchets that originally came with a hard handle, correct?
Subyroo651
Northern IL.
Yes sir, those are the direct replacements for the current line of Hard Handle ratchets. THD72,FHD80,SHD80 etc.
I m 3 weeks into an order for some 3/8" in blue. They had an entire box of 1/4" handles in the 3/8 spot and have to contact the vendor to get it sorted out. So I have a pile of 1/4" handles and naked 3/8 ratchets ugh..
CWP1616L
USA
OK cool. Just two more questions:
1. Will those handles work on older model hard handle ratchets like the F851 and F852 ?
2. Will those handles work in place of soft grip handles on current ratchet models like the FHF80 and FHLF80 ?
Thank you sir. :beer:
Subyroo651
Northern IL.
OK, cool. Just two more questions. :)
I'm not sure about the F851/F852 since I haven't worked with them but that leads into the next question. These are a direct swap for the soft grip handles, that's what I'm doing with mine.
I swapped my THRLF72 and I'm waiting on the 3/8 for my FHR80 and FHRLF80.
If FH936-12(Soft grip) is a replacement for the F851/2 then the FHD80-12 should fit right on.
CWP1616L
USA
Wow that was fast!! Thank you sir. :)
shockwave
Marietta,ga
Has anyone ordered the 1/2 handles?
I was looking up the part numbers for 1/2 but the shd80-12 is not showing a listing thru there website
DTB
I wish I hadn't seen this.. Now I'm gonna have to get a blue hard handle for my FHX80.lol
How hard is the swap?
xj31
I replaced my soft grip handles with screwdriver handles. The soft grip ratchets are a little longer and the regular hard handles don't fit. Here's some 1/2 and 3/8
DTB
I read when they use to swap the screwdriver handles, that the shaft would have to be cut down on the ratchet a little. Are the new style hard handles different in the way they go on the cushion grip ratchets without modification?
xj31
I had to drill the handles, I didn't cut the ratchets. I went with bigger handles, you can see the difference if you look at the 3/8 ratchets in my pic. The bigger handles are screwdriver handles
Subyroo651
Northern IL.
Can someone here provide visual evidence that the Soft-Grip ratchet shafts are longer than the Current Hard Handle ratchet equivalents that are shipping now?
I believe there to be some confusion between the older way of swapping vs. the new handles as of the last year or so.. My 1/4 swapped right over with zero drilling.
shockwave
Marietta,ga
I am not sure about the 1/4 drive ratchets but I do know that the 3/8 are about a 5/16-3/8 shorter and the shank is shorter aswell compared to soft grip. But might be easier to use screwdriver handle vs ratchet handle thou
xj31
on my 1/4 in ratchets, I used 3/8 handles. They also work on Matco ratchets
pault28
Westchester, IL
Man, I would love to put some green hard handles on my 1/2 inch breaker bar and ratchet that currently have the comfort grip handles.
DTB
So the verdict is that the new ratchet shaft with the hard handle is slightly different than the new models with the cushion grip handle?
shockwave
Marietta,ga
Yes they are slightly differently sized probably for more sales vs just selling optional handles that are interchangeable with eachother
